h4 assembly mounting
not sure if this has been talked about before but i figured out a very easy way to install the H4s into the buckets without hit and miss of the mounting screw. i didn't clip the top part of the ring to the bucket and just started the screw at the base, maybe half a turn, just so that its seated, then lift the assembly and secure the lip of the ring to the bucket, then tighten the screw. i messed up a pair of rings by removing the plastic spacer from behind the screw cause i wasn't able to line up the screw with the mounting hole.
ken
87 targa
