NEED A/C HELP....911SC Temp switch...bad??
I just replaced my dash A/C temp switch due to a broken capillary tube. The replacement unit is a little larger (no biggie) but the new switch does not seem to have the clutch on/off "click" to disengage the A/C clutch.
Turning on the blower via the blower switch automatically engages the A/C clutch regardless of the temp switch dial location. With the old switch, I was able to turn off the A/C clutch via the temp switch and just use the blower to recirculate cabin air. Is this a bad switch or since the replacement redesign this function no longer available? |
I just purchased a new temp switch myself but I did not have an old switch to compare the new one to as all of the original AC parts were removed. I am replacing everything. If your new switch doesn't have the "click" at the low temp side then I would say it is not an exact replacement. You may have to live with it that way or add a small switch to duplicate the original switch function. Shouldn't be too hard and then you can use the blower fan without comp activation. I may have to do this mod as I just installed my new switch the other night but have not had a chance to get the compressor installed yet.
72 2.7 Driven! |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/c
Rotating the temp switch full CW & CCW should activate/de-activate the compressor. I would have a look at the two wires behind the switch. A shorted switch will keep the compressor on at all times, and cause evaporator freeze-up. pm me as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Administrator
Take a look at the link below, it may be helpful to you.
Porsche 911 Variable-Speed A/C Blower Switch Installation | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
El Duderino
I think a way to troubleshoot the switch would be to pull out the end of the capillary tube in the evaporator coil and stick it in a glass of ice water. If you turn on the switch the clutch should disengage.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
