I have a 1973 911T. The headlights, window frames and trim pieces look like chrome but are too light to be that. What are they? Pollished aluminium, Anodized.....?
NMCM |
I "think" they are stainless steel.
Jeff Parker 72T *Sold* 98 Neon R/T sedan, red 98 Neon R/T coupe, white 98 Neon R/T coupe, blue |
Banned
i thought they were chromed brass, at least the window frames
I've heard that some frames are chrome over brass, and that others are aluminum. The latter are supposed to be too flimsy to work well for a long time.
They are bright dipped anodized aluminum.
Next.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Senior Registered User
Chrome Looking window frames
My 1971 window frames are alloy. From the factory they were first polished and then bright dipped as stated above.
My head light trim rings for the H-1's are hand made from brass. Randy Jones 1971 911 |
My 73 was hit on the door and the frame was bent and cracked. It was plated brass no mistake about that, same as the early Cobra windshield frames.
PS I think the frames were changed out to earlier 60's prior to this, so they may not be the same as the 73 production.
75 targa 2.7 Lean and green Last edited by Paul Valcourt; 01-31-2003 at 10:29 PM.. |
I'd like to know the answer to this, too. The PO painted my frames black, and I would love to refinish them in the brushed aluminum finish of the 912R in this month's 'Excellence'. Not going to work too well if they are brass...(73T)
David Schultz 1973 911T 2.7 |
Up until the '68 model year, the door window frames were chrome on brass - after that they changed to bright anodised aluminium.
Andy '69 911E--------->R
Andy M&W 904 ... now gone GT-style 356C ... also gone |
If the frame is off the car you can just weigh it -- the brass is a lot heavier than the Al. Other wise maybe you can find a concealed area to drill into or scratch.
