911/930 turbo starting issue
Hi
Apologies if this question /problem has been addressed before but I'm at my whits end trying to figure this out .I have a 1983 930 turbo .I hadn't ran it for some time (in excess of about a year ) .Prior to this I ran the engine at home and the gas ran out . I took the battery out and left the vehicle covered as I wasn't using it .Ive recharged the battery and put 20 litres (uk) of fuel in the tank which as I say was empty . I've tried to turn over the engine ,it won't crank and it just clicks (tick tick tick tick) and the battery light flickers on an off . Prior to this it would turn over . Is 20 litres of fuel enough ? Is it this causing it not to crank or is my battery an issue ? I had a refurbed alternator about 2 years ago . I'm a newbie so I don't quite know where to start Your help would be appreciated Many thanks Derek |
Member 911 Anonymous
"click click click" is your starter solenoid, not engaging due to a fail solenoid or not enough voltage.
What is the voltage reading on the battery? Our cars really need 12.5+ but more importantly enough amps to crank the engine. I would pull the battery and have it tested at a FLAPS. But before that, why not try to jump start her? If starter is the culprit, she will start right up with a gentle push and quick release of the clutch in gear ( 2nd or Reverse, depending on which way she is facing for a safe little run ), then place the ebrake and check he voltage of the battery while on it should read 13.8+
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-31-2016 at 11:08 AM.. |
If over 12.5 at rest, whack the solenoid with a BFH.
Dead battery... Just because you charged it doesnt mean its good. Check the voltage WHILE cranking...
That too but it requires you to go under the car safely and have a helper turn the key. make sure ebrake is up and in neutral. Use a long socket extension and the BFH.It is located RHS rear wheel next to the heater flapper behind the CV axle.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Draco ,thanks for reply .Im a complete newbie at some things 930 based so please bare with me if my questions sound well duffussy . How do I check the voltage at the battery ? Do I do this disconnected from the car ? Using a multi meter ? What the heck is having my battery tested at "Flaps"? All help is greatly appreciated because the 930 is far more capable than I am at the moment
Pics would be appreciated or links to other already posted ones
Thanks guys |
Solenoid is the sausage shaped appendage attached to the starter.
![]() They are notorious for sticking. |
We all started from nothing at some point, you are doing the correct ting by even asking ![]() FLAPS ( Friendly Local Auto Parts Store ), they can LOAD test the battery to insure the health of the battery and it Cold Crank Amps. I usually go to couple of FLAPS to make sure I get the same readings as I found the operator may be a dunce or the machine is in-accurate. Yes, use a Multi-meter and with the battery in the car, place the probes right onthe terminals to get your base reading when cold or sitting over night. Starter and Solenoid: ![]() Tap or smack the smaller cylinder. while trying to start her.
I think you had it here Brother Jim.
Derek... You in driver's seat... car in second gear (some will prefer 1st) with clutch pushed in... ignition on... maybe 2 guys to help push car... get up some rolling speed and let clutch out.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Thanks boys I will start with the battery and work my way from there ,let you know how I get on
Mighty Meatlocker Turbo
Derek, the very first thing you should do, as others suggested, is remove the battery from the car and take it to a local shop or auto parts store, and have them load test it. Even measuring resting battery voltage can be inconclusive (typical resting voltage of a 12v car battery is 12.4-12.6), as you can see proper voltage indicated on your multi-meter even when several cells in the battery are non-operational. By far, the most likely cause of your starter "click" is the battery not supplying enough amperage to the starter solenoid due to low charge or bad cells. |
test the battery and check your connections.....clean them
Change the oil and filter before starting, once you have a good battery crank her a few times to get some oil pressure before starting.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Counterclockwise?
Get some jumper cables and give it a go.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Thanks boys .I bought a multi meter and having charged the battery overnight and left it for around a day I tested it ,it's reading 10.55 volts I'm guessing my battery is kaput ? Need to buy a new one ?
Oh my, Yes, battery is a goner.
Well im thinking thats a good thing and hopefully new battery and easy fix .any suggestions on best battery to buy for a 1983 930 turbo ?
