Registered?
My version of the "sport muffler" mod - - - - - - an alternative to the standard "straight-through" approach.
![]() Cutting open a stock 2 in 1 out muffler revealed not one, but two layers of skin. Drilling out/around the large spot welds takes patience. ![]() ![]() ![]() ![]() Rather than just cutting two holes and adding tips, I tried to route the exhaust gases through a path that somewhat mimics the standard path while letting it ~breathe~ a little easier. The idea was to create a muffler that wasn't too loud, while less restrictive. ![]() Once you cut out the two pipe sections in the middle, you can flatten them out and cut them to a half-moon shape and weld them into the lower chamber to isolate the flow path. There should also be enough old material left over for the two round pieces that plug the two holes - (1) exhaust tip & (1) internal plug. Ergo, no new material needed. Then a butt-load of welding! ![]() ![]() ![]() Viola! A little louder than the single-out DANSK Sport muffler I had with a dramatic increase in throttle response (Unexpected surprise!) and zero droning! I'm digging it. https://youtu.be/iZbZ1aEvxCo Vrmmm Vrmmm!
Brian R Gruppe #757 70T Ex-Waterlogged Rust Bucket http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html |
Under the radar
Nice work. Great documentation.
3 restos WIP = psycho
Sweet! Was this before or after the campout?
Sent from my Nexus 6P using Tapatalk
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Registered?
Before.
I will pay more attention next time!
Nice work Brian.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Nice job!
Post up a sound clip/youtube vid.
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
From his post................https://youtu.be/iZbZ1aEvxCo
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
Registered Minimalist
Well done! I did the "1.0" mod if you will. This looks like a much more logical design.
Have you noticed pop and gurgle? Did you have any issue lining up the dual out? What size are the pipes? ZERO drone? :-)
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
a.k.a. G-man
Sounds great, look great!
(Luckily, none of your welds are visible... )
Сидеть, ложь, Переворачиваться |
Registered?
G-man, I thought I did pretty well with the welds
I know, not the prettiest beads. The original thought was to just tack the tips in place and take it over to the welder since my research revealed that MIGs don't do well with Stainless Steel? But, to my surprise, the tack went on so well that I just finished it off with my MIG. Yah, you can't really see it. Plus, it's not that bad! Now I'm fixated on the welds. Thanks G! Duane - there is "gurgle" when you lift-off the gas, but no popping. Come to think of it, I did have popping with the single-out DANSK Sport. I kind of like the gurgle. The tips are 2.5" U.S. made 304 stainless tubing purchased online from Race Mufflers - Stainless Mufflers - Oval Race Exhaust. Ordered two-feet for $13/ft. - very nice quality.
Looks great - I noticed the double layer of steel on these mufflers as well. I wonder if that is one of the major contributors to the stock mufflers being so quiet compared to any aftermarket set ups?
Wish I could buy one of these from you!
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Under the radar
There used to be a couple of guys, many years ago, that would do the sport mod to stock mufflers. Might be easier to find a good used one.
I don't believe all of the old banana mufflers, like a Dansk, are double skinned.
I agree I think the weight thing and cost of manufacturing probably convinced them not to manufacture this way. Not a lot of people shopping for an aftermarket "Quiet" muffler. Yeah If I had a converted muffler at one time but it was load and droned. I want one that is re-routed like yours is. Probably have to build one myself. Thanks again for sharing this awesomeness!
Very cool mod! Thx for posting. I'm about to cut open my stock banana muffler to see what needs repair, and tempted to perform the same modification while I'm in there.
Couple of questions: Did you stuff the old wadding back in? Or replace it? Same locations? Why the little strips under the new SS tubes? Structural, or to help w alignment, etc? Any pics of the internals, after you were done, but before you buttoned the lid back on? Thanks- and nice work. Jake
'75 911S 3.2 '73 911 T MFI Coupe Silver Metallic (in progress...) Sometimes nothin' can be a real cool hand... |
Registered?
Jake -
Discarded the wadding - it turns into dust when handled. The strips are for structural support - ala M&K. Sorry, no pictures of the innerts before closing her up. I was on a mission by then to finish and forgot to take pictures. It did look just like my drawing, maybe just not as pretty. The trickiest part was fabbing & welding in the two half-moon pieces to isolate the center chamber. You want to make sure you have a pretty good seal in order for the whole back-pressure path-thing to work, plus there's lots of heat where the exhaust manifold attaches so you want to be sure they will hold. Have driven the car about 3K miles this summer with this muffler - I wouldn't trade it for anything else! The sound is just right and the rev-response is intoxicating. Enjoy the journey!
Science is NOT optional
I plan to. And I like this approach. How did you make the cuts for the twin pipes?
PCA member since 1993 |
ASE Master Tech - 35 yrs
looks like you successfully duplicated the euro sport muffler that was installed on my 914-6 in Germany circa 1972
(and which i am still running). ![]() and - or - the old school town-and-country version
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Registered?
I was thinking that might be it but can't imagine how much it would jump around as you bore from the side. Just go perpendicular to the surface best you can and then oval it out to fit the angle of the pipes I suppose.
