kav kav is offline
New User
1969 911 engine bay ground wire?
My 1969 911T has a wonderful one year only wiring harness! This ground wire was not hooked up in the engine bay when I took out the engine, when traced it runs through the tunnel and comes out near the pedal cluster. That end is not currently connected either and I can't see where for it to go? Any ideas where it should go or is it just not used and I forget about it? I don't see it on the Prospero's Garage 68/69 wiring diagram either?
Engine bay side:
Through the tunnel near the pedal cluster:
Cheers
-Kav.
Old 07-25-2017, 11:38 PM
ROW '78 911 Targa
timmy2's Avatar
Spare wire. Brown/white is not a ground. It is a switched carrier wire when used.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-26-2017, 09:09 AM
ROW '78 911 Targa
timmy2's Avatar
Use these for your car, print and paste together.
https://www.dropbox.com/s/sv32h1l1bcowjru/SL33-lft%20electrical%20diagram.pdf?dl=0
https://www.dropbox.com/s/ilii4yf1w1ttv93/SL33-Rt%20electrical%20diagram.pdf?dl=0
Dennis
Old 07-26-2017, 09:12 AM
kav kav is offline
New User
Thanks very much Dennis!
-Kav
Old 07-27-2017, 08:02 AM
