Window Switch Replacment
The passenger window switch on the driver side door on my '83 SC Coupe does not work. I am pretty sure that the switch may be the problem as the passenger window works fine with the switch on the passenger side. I want to replace the suspect switch with a spare that I have. The problem is that I am unsure of how to remove the switch. I have been searching and reading and it sounds as if the switch can just be pulled out without removing the door card. Is this correct? Can someone please share detailed instruction for switch removal? I am concerned that I may damage something if I just try to pry the switch out.
That's about it from what I recall. I used a putty knife with some cardboard on the door panel to pry against so as not to scratch up the vinyl .
JUAN '80SC Targa |
Juan is correct, the switch is just held in place by pressure, so just gently pry on the top and bottom repeatedly and it will come right out. Be forewarned, you either need to take photos of the position of what terminals each wire connects to, or write it down as there are approximately 5 wires and 5 terminals, and failure to reconnect the correct terminals will leave you with a non-functional switch. There are a lot of posts on this, so f you do get it wrong it isn't the end of the world.
Regards, David
__________________ David Yerkes 1987 911 Targa - GP White |
Also - wiring is very short - which doesn't allow much room to make the switch. (Hah- no pun intended!)
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Vintage Owner
Be careful to note the position of the wires as they are short and difficult to always discern their color (due to aging of the wires). This would have been a great place for Porsche to have used a multi-pin connector rather than 6 individual wires attached to the switch.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Thanks for all of the replys. I will feel a little more confident now when I pry the switch out. Sounds like a good job for the nylon trim tools.
You may find it's just a case of one of the terminals (connectors) has fallen off or needs reseating.
Banned but not out, yet..
You may want to create a diagram of which color wires go to which spades, which you will no doubt use again. Also hemostats come in handy to keep the wires from disappearing into the black abyss. K
An air cooled refrigerator. ‘Mein Teil’ |
Still here
Make sure to disconnect your battery when doing this. Otherwise likely you'll blow a fuse when the wires touch when you've disconnected the switch.
Senior Member
Senior Member
Wildman Emeritus
Hemostat works quite well for sliding spades back on as it is tight for fingers with the short wires.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
That is a great tip!
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() ![]() ![]() ^^^^^ Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I had the same issue four years ago when I purchased my car and sprayed the switch with contact cleaner and it has worked fine ever since.
Thanks again for all of the information. Hopefully next week I will have some time to tackle this project, now with a little more confidence.
Yes that is Pasha cloth
What's the difference between the switches sold as right side and left side? Looking at the photos above the studs all appear the same.
84 RoW, slicktop coupe, with Pascha baby! 08 GTS Cayenne |
They are the same
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
