SC Running Warm - not what you think.
The last couple days I noticed my oil temp was climbing higher than usual. My engine has always stayed at the first tick mark (190 degs) or thereabouts. Yesterday it came close to the second tick mark (almost 250 degs).
I started searching last night for things to check. I had already confirmed the fender loop was hot. That's an easy one. Today I took a look at the engine and... ![]() Yes. That's a gross mouse nest made of insulation on cylinders 2 & 3. I'm lucky I didn't have an engine fire. I pulled the fan and cleaned it all out today. How do I stop this from happening again. I have been having a losing battle with mice. So far this, eaten speaker wires, eaten vacuum hose, mouse poop. Help!!! Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
Member 911 Anonymous
Got to get rid of the food source or seal it away. The wire thing, I surmise that is like crack for mice.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Fleabit peanut monkey
On the bright side you paid attention to your oil temp and skirted disaster.
https://www.tractorsupply.com/tsc/product/tomcat-rat-and-mouse-place-pacs-22-piece-pail-3-oz-each Just lay them under the Porsche or near suspect entry points. Maybe try some of those sticky mouse catchers to assess the depth of your problem. If you catch one every other night and it does not thin out over time, go big guns.
1981 911SC Targa |
I think it's more really good shelter first and if there's wires there, hellz yes. We can knaw.
Lost a $1,200 pool heater that way. (The heater was fine, replacing the mother board and such was 2/3rds the cost of new)
1981 911SC Targa |
87 - 911
Couple moth balls placed around the perimeter of the building and one each in the fruck, pass compartment and engine.
I've had good luck with the jaw-type traps and peanut butter for bait. Keep a couple loaded up near the car. Mice are stupid, you can catch them all. Rats, on the other hand, are much more difficult.
Banned but not out, yet..
If you park in a locked garage, keep both your hood and fronk open. Also keep your heater vents closed. Mice like dark hidden places.
An air cooled refrigerator. ‘Mein Teil’ |
Caveman Hammer Mechanic
Call these guys:
https://youtu.be/8xbn_vMY18I
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Get a cat.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
porscheboy1
I use a lethal ball bearing mouse trap. My tom cat.
Thread Tools | |
Rate This Thread | |
