Front hub resto
Hi All!
I am restoring a -71 911T and are currently looking on what to do with the aluminium front hubs to make them last.
1) Powdercoat
2) Anodize
3) Clear coat
4) Leave as is
5) Other
Thanks for any input.
Jörgen Forssling
Göteborg
SWEDEN
Old 08-11-2017, 05:57 AM
H-viken's Avatar
Leave as is.
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 08-11-2017, 09:07 AM
The 9 Store
Vapor blast
All used parts sold as is.
Old 08-11-2017, 10:34 AM
Originally Posted by mepstein View Post
Vapor blast
OK, vapor blast and then leave as is?
//Jörgen
Old 08-11-2017, 11:10 PM
The 9 Store
//Jörgen
Yes
Old 08-12-2017, 06:12 AM
Yes
Thanks!
Old 08-12-2017, 06:47 AM
The 9 Store
We vapor blast a lot of aluminum parts. It smooths the surface without removing metal. Sort of like ball burnishing. Stays much cleaner and better looking than glass bead blasting.
Old 08-12-2017, 06:58 AM
TheSt|G's Avatar
^^^ That looks great!
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 08-12-2017, 07:36 AM
seafeye's Avatar
Aluminum has an open pores feel to it after it has been blasted by glass or that type of media. So after you clean it. Take a scowling pad and rub it with that and PB Blaster. It seals the surface making it harder for it to stain or soak up oils/water etc.
What me speed?
Old 08-12-2017, 11:21 AM
Should I let the old bearing races be in the hub while blasting? I'm thinking to protect the surface.
//Jörgen
Old 08-14-2017, 01:26 AM
