930 first valave adj - Torque question
Hi,
I have been doing my first valve adj on my 930. Been a lot of fun.
I am now trying to torque the valve covers.
I was able to do the top covers except for drivers side rear nut because there was a tube on the way of getting the torque wrench on. I suppose I could of bent it in a way that the wrench would fit and the hose would still be functional, but since it was the top cover and all of the torqued nuts were around 3 threads ahowing I did it by feel with a box wrencg and it looked about the same as the rest.
Now we get to the bottom covers. There is NO way I can see to get a socket and torque wrench on the bottom nuts without removing the heat exchangers? Am I doinf something wrong? Do I need to remove the heat exchangers to adjust the valves and troque the covers??
Thx for the help!
larry
Old 02-02-2003, 06:30 PM
Just tighten the nuts you don't have to torque them. Just don't overtorque
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-02-2003, 07:07 PM
