My airflow sensor stop is loose
Hello.
My airflow sensor stop is loose and rattling around: See this pic... The red and green screws spin but do not tighten... Do I have to remove the Air intake boot to get to the top sides? Do my blue and orange arrows point at Nuts not shown in the pic for some reason? Thanks. |
It's going to be a tight squeeze, but I think you can probably get a wrench between the air box housing where the filter sits and the back of the air flow sensor . You should be able to get to the top of your green and red screws without removing the boot. The nuts pictured in the schematic are there (see the top of your red arrow) The rear screw has a washer and nut on top of the air flow sensor, the front screw has the same, but the nut sits in a little hex well inside the plastic connector for the AFS electrical connector.
Some pics of the nut and connector (your blue and orange) in this thread. You can see one AFS has the stop installed, one doesn't. Can I use this air sensor plate?
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. Last edited by Jameel; 08-17-2017 at 09:12 AM.. |
Fantastic thanks Jameel, I'll try this later... the link to those other pics is just what I needed.
