Brakefluid Overflow Exit Point
Hi All,
I just discovered a small leak just behind the front oil cooler on my 82 911SC Targa. I located a small clear tub that looks to be a drain for some type of fluid. It does not have a smell and looks to match the color of brake fluid. I did just replace the rear pads, so tis would make sense. Is that where the line terminates?
Chris ------------------- 1971 911E (Tangerine/Black) 1987 951 (Guards Red/Black) 1985 928S Euro (Prussian Blue/Blue) |
I just bled mine and don't remember any hose being on the bleeder screws nor have I seen overflow lines ever on calipers. So unless someone added that I would say its something else.
Brake fluid definitely has a smell. Open a bottle if you need to refresh your memory.
Thought I had a rear main (flywheel) seal but thankfully it was just the clutch slave cylinder leaking brake fluid into my bell housing. Collect a bit to smell it if it's still leaking.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
76 911S Targa
The brake fluid reservoir overflow exits from a clear plastic tube at the front of the car. You can follow the overflow line from the reservoir to the exit point if you lift the frunk liner out of the way.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Can you show another pic from a wider angle?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
The OP could have a front cooler other than the one commonly found in the wheel well. If so, this may be the brake fluid over flow tube. Yes, a wider angle shot would help.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
El Duderino
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 09-05-2017 at 08:45 PM.. |
I've seen some lines exit behind the front bumper, so if a cooler was mounted there, well that's that. I searched the forum and found some exit elsewhere but this seems MY dependent.
Yes, this is the end of overfill-drain-tube. got the same install on my SC.
when filler is up full and you work on brakes (e.g. pad change) and push back the caliper pistons pushing back fluid, the reservoir may overflow. so allways check fluid level first, and if necessary drain some fluid first. when bleeding brake lines by pressure, allways block off drain line with a tight clasp!!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
