GOM (Grumpy Old Man)
Busta Rib's Avatar
WiFi Borescope...do eet!
I recently added a WiFi borescope to my toolbox and it has really come in handy. You can find them on Ebay or Amazon for about $25-35 and it will work with most iPhones and Android smartphones. It is well worth the price for laying eyeballs on hard-to-reach areas. I don't know what took me so long to discover this device. If you don't already have one, pick one up and have fun.
Instagram: @3pedalposse
Old 09-04-2017, 01:55 PM
Vulnerari Praesidio
That is simply brilliant.
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 09-04-2017, 03:59 PM
Just ordered one!
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-04-2017, 05:14 PM
dwight45
dwight45's Avatar
Borescope
It won't work on my android. Not compatible. I wasted my money.
Old 09-04-2017, 05:26 PM
Same here, just sent it back could not connect.
Old 09-08-2017, 02:10 PM
Halm's Avatar
What phone and version of Android are you running?
'17 Cayenne
Old 09-08-2017, 02:12 PM
Absolutely brilliant. Thanks for pointing out. I had only seen the ones with a built-in screen before, Mine works great with both iphone 6, and iPad Air2.
1983 911SC
2005 911S
Old 09-15-2017, 08:52 AM
Great... I can skip my next colonoscopy.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-15-2017, 10:38 AM
I just bought this one for several projects as it came highly recommended on a plane forum:
https://www.amazon.com/gp/product/B00GY7C9ZW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
The thing a like about it is the ability to turn the camera back towards you. I just used to it run wiring in a wall at my nephew's place. It as great to see what was behind the wall before cutting in.
It hooked it up to my Android phone and I downloaded camerafi. Worked like a charm. Snap stills or video - easy. Adjustable LED lighting at the end.
Old 09-15-2017, 10:58 AM
Eng-o-neer
Tremelune's Avatar
Which one did you get? The two I've used have trouble focusing at close distances, and that's...a bummer.
Make sure you get one with a stiff or stiffish cable. Floppy cables make these things nearly impossible to snake through cars.
With the rate at which cable connectors change (at least for iPhones), I'd go with a wifi or bluetooth one...
Old 09-17-2017, 06:07 PM
I bought the Depstech one.
1983 911SC
2005 911S
Old 09-18-2017, 11:10 AM
what is the diameter of the scope? (how small is it?)
1987 Porsche 911 Carrera Coupe
Old 09-18-2017, 11:43 AM
the one I bought is 8.5mm diameter.
Old 09-18-2017, 02:02 PM
For those using Android, just plug the USB cable directly into the phone. You don't actually require the wifi module as needed with IPhone.
Old 09-18-2017, 04:32 PM
