911, 914-6, 928
Widebody 911 rear wheels
On a 911 with 930 flares front and rear, what 17" rear Fuchs copies will give it 'the look' when combined with 7x16 OE Fuchs on the front? The look of 11x17 with 315's is great; what brand and ET will work on the rear (with reasonable spacers) to get there? Rear OE 9x16 don't have enough tire choices.
Yes, I have done a forum search but still not satisfied ..... Steve |
GOM (Grumpy Old Man)
Your best bet is to check with Fikse or Braid. I believe they offer 11" rear Fuchs reps. With the right offset, you should be able to run without spacers. Good luck.
Instagram: @3pedalposse |
Under the radar
IMO to get "the look", you are going to have to go to something like a 17 x9 in the front to match those rears you have in mind.
9 x17 ET13 255/40 11 x17 ET-8 315/35
Crotchety Old Bastard
Probably seen these pics before, I run 9x16 front 12.75x17 rear on a 930. Tires are 245/45-16 and 315/35-17.
Ran 9x16 and 12x17 on a widebody SC, same tires. 9x16 are stock 930 rears, they will bolt on to the SC front hubs with no spacers.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
911, 914-6, 928
Too bad Euromeister doesn't make 11's. Braid wants $1100 each; not in the budget. Not a track car.
![]() thread
MBruns for President
Hey my old car (with 16 inch wheels and spacers)
Here it is with the Fikse 17 wheels ![]() ![]()
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I had my front 7" Euromeisters widened to 9". I'm sure you could do the same to rears.
Matt - 84 Carrera |
Hey Hey Hey - for a track car - wheels should be exactly where you are spending money. Personally -= I have broken two wheels at the track that were sub standard... I can tell you first hand - this is not an area you want to scrimp...
911, 914-6, 928
Under the radar
There may be a reason why some manufactures don't make 11 or 12 inch wide wheels. BTW no one has mentioned Lindsey's wheels. Might be worth a look.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-29-2017 at 09:40 AM.. |
With 315's, any kind of "spirited driving" in a CCW direction allows the sidewall flex to contact the oil lines without proper offset.
I'd buy CCW wheels, in the future you can just change barrels and go to 18's where all the nice sizes exist
1980 911 - Metzger 3.6L 2016 Cayman S |
STR Carrera: WIDE front wheels Part 2 Not noted in that post is that per Weldcraft's suggestion I painted both the inside and outside of the barrel, acid etching primer followed with flat black. Car has seen 100s of autocross runs and a track day on them, ymmv. It was a little bit tough dismounting / mounting tires as they have to pop over both new weld beads.
Matt - 84 Carrera |
911, 914-6, 928
Administrator
7s and 9s will fit on a regularly-flared Carrera. On a widebody, they're going to look a little skinny -- at least by contemporary standards. 9s and 11s are probably what you want.
Granted, I'm biased. But I have 9-1/2x11x17 Lindsey Racing Fuchs.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
911, 914-6, 928
I have OE 9 x 16's on the back of my 930 and I exchanged the stock 28 mm spacers for 50 mm adapters, the look is much better. But, what could be done with 9 x 17's on the back of the wide SC without using huge spacers?
for a 9 to fill a wheel well like an 11ET-8 it would need to be a 9 ET-33 ie a stock 9ET15 w/ a 48mm spacer w/b 911 really want a 8 to 9" front and 10 to 12" rear
