High Life's Avatar
Another "Where do these go?" thread - Dash light bulbs
I am cleaning up the horrific wiring mess under my dash and of course came across a couple of lights that are not "plugged" into a holder or a base and was hoping someone might know where they go.
The bottom bulb in the pic lights up when I move the fan lever and stays on = so I guess it must light up the little fan icon? (cant see anything behind there due to the radio and the ashtray. It has yellow/red wire and black wire running to it.
The top bulb circled does not come on unless you turn on the light switch. It does NOT go to the ashtray - that bulb is in place and working. It has 4 wires - blue - 2 brown and a black (i think).
1981 911SC
Old 09-06-2017, 05:33 PM
pete3799's Avatar
They go to the slide control panel. The fan one you've figured out. They push into the round plastic holes in the back. The plastic deforms from the heat of the bulbs so they may not push in and stay. Feel around ....you'll find them.
Pete
79 911SC RoW
Old 09-06-2017, 06:23 PM
proporsche's Avatar
hi..as mentioned above the right one goes to the fresh ar unit sliders the one in circle goes to the ashtray..at least looks like, here slide inside this rubber
Ivan
Old 09-06-2017, 09:54 PM
Pete is correct, they both belong to the ventilation panel.
Ivan, the bulb to the ashtray has one grey and one brown wire.
Old 09-07-2017, 02:32 AM
Maybe a good time to fuse your dash and check other connections so your car doesn't burn up.
Old 09-07-2017, 02:42 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dash fuse.
ABSOLUTELY!!!!!!
And, here's how to do it.
Good luck,
Gerry
pm me as needed-I posted other upgrades.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-07-2017, 09:34 AM
schoward's Avatar
4 corners of ventilation panel with fan icon one as you mention for when fan is on
You will likely need to tack them in web some glue as deformation makes them fall out
Worst location and one of the worst contortions of my body I've ever had to do to fix something. There literally should be a procedure on how to contort yourself. I recall feet up in air by the driver side headrest is a good start.
Scott
1981 911SC Targa - Platinum Metallic
Old 09-07-2017, 09:56 AM
Burnin' Rubber
Koizumi's Avatar
These 4 bulbs are really a pain to access! And glue only seems to last a year tops, then they pop right back out. I installed LEDs but the heat from 33 years of incandescent bulbs distorted the plastic holders.
Terrible design!
Old 09-07-2017, 10:05 AM
proporsche's Avatar
hi Peter..yup that is correct but on the picture you do not see any color;-) of wires..or?
Ivan
Old 09-07-2017, 10:53 AM
stevie 77 930's Avatar
Yes, as others have said, accessing the ventilation panel is a real pain. When I finally couldn't stand not having these bulbs dangling around I removed the radio for better access. i was able to reach in and reinsert the bulbs into the sockets. I used a little bit sticky automotive caulk/sealer to help keep them in place. Problem solved
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 09-07-2017, 07:44 PM
