Tachometer on 1982 3.0 SC to coil instead of dizzy
Hello,
I'm considering to change my dizzy to a 123ignition variant, because the vacuumbox is broken and EOL. The consequence is that I need to eliminate the CDI box and hook up my tacho to the coil. I don't know what signal levels the tacho expects and what the coil is generating (I was told that it needs to be GND levelled).
I'm not sure if the tach-adapt box can support this. And even if so, probably not available here in Europe. I have a background in electronics, so if i'd had the specs of the tach and the coil, I would be able to make something myself.
THe car is a 1982 3.0 SC Targa (US version)
Regards
Bas
Old 09-08-2017, 02:39 AM
They don't make a 123 for an sc. i know on some msd installs you can plug in tach and it will work with no mods.
Old 09-08-2017, 03:54 AM
304065's Avatar
Tachometer Compatibility Chart
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-08-2017, 07:02 AM
ROW '78 911 Targa
timmy2's Avatar
Partsklassic dot com may have the parts you need to repair your distributor.
Email them.
Or post a WTB (want to buy) in the parts classifieds. I'm sure someone has a vacuum pod from a worn distributor kicking around.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-08-2017, 07:11 AM
Tags
123 ignition , 123ignition , coil , dizzy , tacho
