Alex599's Avatar
DME relay, easy fix?
Hi guys,
I just tested a spare DME I received with the car when I bought it. It failed. Now, I fixed my fog light relay quite easily a few months ago. It was a connection clearance issue, fairly easy fix. I thought I'd check with my fellow Pelicans before I drop $100 on a new one. Is there an easy fix? What should I be looking for?
Thanks,
Alex
1984 Carrera 3.2 Cabriolet
Old 09-15-2017, 11:59 AM
JackkTheMackk's Avatar
http://www.ftech9.com/new-products/911-ss
Purchase that DME relay. I have one of theirs in my 944 turbo with the pump prime. SSD relay will last forever.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
‘90 OM606 Swapped SWB 300GD
IG: @JackSchroederCreative
Old 09-15-2017, 12:04 PM
^^^^Same for me...works great in my '87 911. I love the pump-prime feature.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 09-15-2017, 12:24 PM
Kind of Blue
MrBonus's Avatar
Do you mean this one?
911 Solid-State Relay (Pump-Prime) — Focus 9 Technology, LLC
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 09-15-2017, 01:03 PM
it was an easy fix for me - bad solder joints. I reflowed them and it came back to life.
Old 09-15-2017, 01:18 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dme
The very usual suspect......
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-15-2017, 01:51 PM
That is interesting I have 2 questions though: How long does the fuel pump run when the ignition is turned on? Can the ignition be on for a while without burning the fuel pump?
Old 09-15-2017, 02:19 PM
Alex599's Avatar
Thanks all,
I'll definitely go the ftech9 route if I can't fix mine. In the picture below, should the solder be bridged at the pen tip?
Thanks,
Alex
Old 09-15-2017, 02:35 PM
Buzz that sucker out - pretty much it is two relays. Find that open. Here is a nice thread on the workings of the dual relay unit.
https://dorkiphus.net/porsche/showthread.php?t=16859
and yes, I believe that is bridged. Flip it over and look at the width of the metal landing there...
Old 09-15-2017, 02:51 PM
by the way, this contact looks suspect (could be the photo though). I would reflow all solder joints and see how it works.
Old 09-15-2017, 02:54 PM
The prime only runs the pump for three seconds and then shuts off. It will not burn your pump up.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
Old 09-15-2017, 03:01 PM
That is good but follow-up question: if for some reason, while doing car maintenance, the ignition is turned on and off several times, minutes apart is there any chance that pump priming will stress something?
Old 09-15-2017, 03:18 PM
gtc gtc is offline
abides.
gtc's Avatar
No
Graham
1984 Carrera Targa
Old 09-15-2017, 03:53 PM
Great! Thanks for posting the link to the FTech9 device, and the pump primer in particular.
Old 09-15-2017, 04:14 PM
Vintage Owner
Jack Stands's Avatar
Would it make sense to fuse the power to the DME? Supposedly Porsche does not have the power to the DME fused.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 09-16-2017, 06:11 AM
Dme
According to my 1986 3.2 factory manual, the DME relay is not fused.
Don't know why?
Gerry
1986 911 Targa.
Only in L.A.:
Old 09-16-2017, 07:06 AM
DanielDudley's Avatar
It's a primary wire from the battery. It would have a fusible link if it was in a modern car. The fuel pump wire goes from the DME relay to the fuse box, and from there to the fuel pump.
I fixed my old DME, and then replaced it with the solid state unit. Because I can always hear the fuel pump run before I start the car, I know that both the relay and the pump are working. I like that.
Also, since it is considered a pretty good idea to have a spare relay, I use the old relay as my spare.
Old 09-16-2017, 07:57 AM
Kind of Blue
MrBonus's Avatar
I just ordered one of the prime-pump relays. I've never had the DME relay fail but I have noticed that it takes a few seconds of the engine turning over to fire up the engine and I'm wondering if this will reduce the strain on the starter.
Old 09-18-2017, 06:43 AM
I have read that the circuit needs to see a certain minimum rpm of the engine before turning on the fuel pump relay (I have read 200)...could be why you have to crank for a bit to get it started. The idea being they didn't want the fuel pump running without the engine running.
Old 09-18-2017, 08:04 AM
Thus, the reason for the flywheel sensors....
Gerry
1986 911 Targa.
Only in L.A.:
Old 09-18-2017, 11:35 AM
