SC to RSR Project contimues....Some suspension work
Made a lot of progress in a number of areas this week.
Shell is prepped and ready for the mock up.
I have gone into painstaking detail on every area of this build.
The initial plan, the acquisition of parts, the work. Every last detail has been planned to the last detail. I know there will be challenges along the way but things are coming together well so far.
Here are a few more pics working on the suspension mock up.... I am interested in comments.
Old 09-23-2017, 09:41 AM
Congratulations, lots of devotion to get to the steps seen in these pictures. Are you doing a centre oil cooler?
Old 09-23-2017, 09:52 AM
Looks very nice! Whose struts are you using?
Can't tell from the pictures: Do you have shock tower reinforcement welded in to support the rear coil-overs?
Old 09-23-2017, 06:07 PM
I'm using Bilstein struts and shocks. Yes I have reinforced the rear shock towers.
Old 09-26-2017, 08:04 AM
Thank you! No I'm not using a center oil cooler. I'm using a well fanned Carrera style fender oil cooler. I'm using an S style bumper for a cleaner look.
Old 09-26-2017, 08:06 AM
I have a dumb question....
When you go to coilover... what do you do about the torsion tube hole?
1987 Porsche 911 Carrera Coupe
Old 09-26-2017, 09:28 AM
I guess it's safe to assume you're referring to the front? If so I like to use rubber expandable freeze plugs.
They will seal the hole so they won't fill up with dirt/water.
Old 09-26-2017, 12:06 PM
Are you running 15's with the rsr front struts? Any chance that you can measure the spindle drop on these yellow Bilsteins? I have read they are 12mm "raised" over stock in contrast to to the old version green rsr struts that were 11mm. I can't find the information anywhere!
Don't forget to post more pictures as your car comes together.
Old 09-26-2017, 12:26 PM
No, I'll be using 17" wheels. Yes, you are correct it is a 12mm difference from stock. I will absolutely post more pictures as I go. Thank you.
Old 09-27-2017, 06:31 AM
