camdon's Avatar
Any BBS gurus? What are these from?
Found these in the back of my shop. Been sitting there for years. Cant remember where or what they were from?
Any help? Want to sell them once I find out.
Thanks guys
A few P-cars in the garage
Old 09-29-2017, 08:14 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Those are typically 16x8 911 rear wheels for SC/Carrera flared cars. They fit the rear of those cars just like a 16x8 Fuchs 911/930 rear wheel. Also people have found that the low offset (+11mm) of these 16x8 wheels can fit the front of a 930. BBS originally spec'd an offset of +23mm or +28mm for the 930. But the lower +11mm offset on the front of the 930 makes for some added steering effort even though it does a nice job of pushing the wheels further out to the fenders.
They appear they were originally gold and someone repainted them silver. No big deal to take them apart and have the centers repainted again. But it's tedious work to remove all 34 nuts and then split the rims from the center. The center is sealed to the rims with silicone like a sandwich with mayo. Rims = bread, center = meat, silicone = mayo. Since they're glued together like that, takes some work to get them separated. Also use a good non-acid curing sealant like Dow Corning 832 silicone to re-seal them.
Good luck with the sale. Nice pair of wheels and nice centercaps are becoming harder to find. Although they can be refurbished with some parts from places like Black Forest Industries. They sell the retaining clips that hold the "waffle" to the center hex and also sell replacement BBS center logos.
Paul Ehrlich Wheel Works has a pretty comprehensive listing of BBS wheel sets in case you're curious what other models they may fit.
Complete BBS RS model list | Ehrlich Wheel Works The RS013 shows up on the list as a 911, 930 and 944 application. 944 thru '86.
Kevin L
'86 Carrera "Larry"
Old 09-29-2017, 08:32 AM
Formerly known as Syzygy
Canada Kev's Avatar
The BBS RS 013 is an 8 x 16 ET 11 wheel for Porsche fitment.
Oops, someone beat me to it, but with far more comprehensive info.
Kevin
Old 09-29-2017, 08:34 AM
camdon's Avatar
Thanks guys.
I actually have 4 of them. Let me check the number/sizes on the others.
Anyone interested just PM please.
Old 09-29-2017, 08:39 AM
camdon's Avatar
Someone said they wanted these but I can find the PM?
Please PM again.
Old 10-01-2017, 12:01 PM
camdon's Avatar
1000.00 before ebay?
Old 10-09-2017, 08:41 AM
smarens's Avatar
I was looking for a 7"x16" BBS RS with ET23 backspace (normal Front); are all 4 of yours the 8"?
PM sent
1975 914 1.8l
1979 911SC Targa - In Restoration
1972 Pantera
Dune Buggy Dual Port 1835cc
1980 911SC Targa - Driver/Winter Project
Old 10-09-2017, 09:29 AM
camdon's Avatar
I will have to get to the warehouse and check
Old 10-09-2017, 10:17 AM
camdon's Avatar
Old 10-18-2017, 11:28 AM
Less brakes, more gas!
euro911sc's Avatar
Too bad they are not ET23s! Then you would have something to work with! Even so... With a little spit and polish you could end up with this:
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-19-2017, 06:47 AM
MBruns for President
JeremyD's Avatar
They used to sell the BBS wheels like these as an improvement over the fuchs back in the day - rightly so - they raced with the BBS - and they are lighter than the fuchs - and they will fit over bigger brake packages....
Only downside is that they are an absolute biotch to clean...........
Old 10-19-2017, 07:06 AM
euro911sc's Avatar
^^^^ LOL This!
Michael
'13 Cayenne GTS
Old 10-19-2017, 07:12 AM
Chain fence eating turbo
Dang, I wished I stumbled across awesome items to sell like this I didn't know I had....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-19-2017, 07:19 AM
Schleprock
KTL's Avatar
If you look closely, those are a set of 16x8 ET+11 and 16x9 ET+11. Those are a nice fit for a widebody/930. The ET+11 16x8 pushes the wheel out to the front fender a bit more than the ET+23 or ET+28 version. But some may not like the "tapered" look of the outer rim shell used on the ET+11 16x8, compared to the "stepped" outer rim of the 16x9 wheel.
They are indeed a prison sentence to clean. Especially if they've been neglected far too long like this
And they're even worse to break down and reassemble. 34 nuts & bolts, silicone sealant, cleaning...... I pity the fools (like me & Michael) who choose to refinish these wheels.
Kevin L
'86 Carrera "Larry"
Old 10-19-2017, 08:25 AM
