How do I install these?
I’m asking how do I remove the old ones without breaking the levers they are attached to?
![]() Sent from my iPhone using Tapatalk
http://9309700485earlyturbo.wordpress.com |
They just pull off- friction fit; don't bend side to side.
Rutager West 1977 911S Targa Chocolate Brown |
Tried this but they are on tight worry about breaking the levers.
Heat gun gentle?
1986 Bosch Icon Wipers coupe. |
Jacksonville, Fl
Yup, heat gun worked them loose for me. Low, low heat.
Alex Jacksonville, Fl '88 Carrera, Guards Red |
NO!
heats up way to fast and hot! even gentle. use a hair drier and then some wood to hammer off from backside gently.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Put a pair of vise grips on the backside, snug but not tight.
Gently tap the grips with a small hammer. Did not need heat. |
Go it off! Taped it off a few times to keep from damaging it the pulled off with pliers.
Then found this.. It was installed upside down.. it has faded just on the side it was installed. So debating on whether to install the new one or try to refurbish the original. ![]()
http://9309700485earlyturbo.wordpress.com Last edited by 93097004xx; 10-13-2017 at 09:48 AM.. |
Refurbish is easy.
Pan of hot RIT red dye for a couple hours. Use white-out in the recesses, it's latex paint. wipe off the excess. |
