Sturmvogel
Trailering for the first time
I think I have it figured out, all except for the tie-downs. Does someone have a quick lesson for me? One of the things I have learned is that some tie down hardware is too big to fit through Fuchs wheels.
But I sure could use some advice form those who have BTDT. |
Another one to add; don't leave it in gear.
Sturmvogel
1 tip, be careful approaching off ramps from the highway. IT WILL take longer to slow down and some ramps have abrupt turns. Was "alerted" to this way back in my early trailering carrier
Here you can see the usual direct hook ratchet w/ a snap hook on the other end(bottom) and 2 versions of thru the wheel straps. Many use the above method, a strap is fed through the wheel and then the snap hook fastens to both ends of the strap. The ratchet will then attach to the trailer. A much simpler arrangement is to forego the snap hook, just have a ring(as seen on the thru the wheel strap ends) attached to one end of the strap. Now the dead end is fed thru the wheel through the ring then to the ratchet. Be sure to have at least 3 or 4 wraps of the dead end at the ratchet end. leave the car in neutral and apply the parking brake. position the car on the trailer so that tongue weight is w/i the trucks load range. Once the proper position of the car on the trailer is determined permanent wheel stops will ensure future placement. Wheel stop ![]()
+5 "...position the car on the trailer so that tongue weight is w/i the trucks load range...." This also includes any additional cargo (gas, tools, etc)
Last thing you want is trailer sway at 70 mph!!
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
The 9 Store
At our shop, I may tow 3-4 different cars a week. The wheel straps make it easy.
Anytime you tow, drive for 5-10 minutes, stop and recheck the straps. If its raining, give yourself plenty of braking distance.
All used parts sold as is. |
Thread Tools | |
Rate This Thread | |
