Brake bias, how to calculate ?
How do you calculate the brake bias ?
Do you only consider the area of the caliper pistons ? or do you take in consideration all the components of the brake system ? |
Administrator
Take a look at the link below to an earlier thread where this is discussed. Hope this helps you a bit.
Brake bias adjustment |
then factor the effective radius of the rotors, which is the distance from the axle center line to the piston center-line arc, this is almost always different f/r even when the rotors have the same radius then factor the effect of different pad Mu front vs rear(if any) other almost negligible factors are the weight of all the rotating components the effect of brake line size and rigidity, the effect of component rigidity and the net tire OD
Bill,
Thanks for your answer. Pad size has something to do ? |
No, pads sizes affects pad and rotor longevity and to a lesser extent feel
