Stahler's Avatar
Starter problem - again and again
Hi guys,
frequently when I start my '68 SWB 2.0 after a couple of weeks the same thing happens: fuel pump works, dash lamps work but starter doesn't. Four, five attempts - and all of a sudden it works and everything is fine. I don't think it's a battery problem, battery is permanently connected to C-Tek charger. Any suggestions?
Thanks a lot
Peter
Peter
1968 911 2.0 SWB Karmann Coupe
1993 Ducati 750 SS
Old 10-18-2017, 12:42 PM
gtc gtc is offline
abides.
gtc's Avatar
Bad starter.
Graham
1984 Carrera Targa
Old 10-18-2017, 12:52 PM
Originally Posted by gtc View Post
Bad starter.
Simple, isn't it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-18-2017, 01:25 PM
pete3799's Avatar
Or a bad chassis ground perhaps.
Pete
79 911SC RoW
Old 10-18-2017, 01:38 PM
happens all the time... Starter solenoid plunger gets 'sticky' in its bore. Can't slide quite far enough to engage the contactors. Take the starter apart, clean and lube and be good to go for many more years.
Old 10-18-2017, 02:02 PM
The wire bringing 12v to the starter can get gnarly overtime with engine heat and elements. Try to put a remote starter on the two lugs on the starter to see if you get consistent starts. It could be just the wire.
Old 10-19-2017, 02:51 AM
T77911S's Avatar
its probably a bad solenoid. the solenoid can be "rebuilt" for FREE, but you have to know how to solder. basically the contacts get burned and erode but only on about half. you can rotate them to the good side.
first I would make sure the battery is charged and good. have it tested.
clean ALL major power connections. both positive and grounds.
verify you are getting power to the solenoid from the ignition switch when it wont start.
I would use a test light. compare the light to the battery connection at the starter to the ign sw power. a MM will measure 12v but there not be enough power there to pull in the solenoid
here is my rebuild
SOLENOID and STARTER rebuild......finally
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-19-2017, 02:56 AM
All good ideas above. I would also include possible bad ignition switch.
Old 10-19-2017, 04:13 AM
I was on the verge or replacing the starter on my '88 3.2 because every once in a while when I turned the key... noting. A couple more tries, and the starter would go. Decided to do the simple stuff first & replaced the ground strap under the car. Bingo... starter's been perfect ever since. Clean connections are important here as the starter demands a greater power draw than most other items. If the simple things don't work, then move on to the more pricey options.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-19-2017, 06:21 AM
kent olsen's Avatar
Pete3799, I agree it could be the ground. I spent a couple hours one day and cleaned every ground on the car. Some where looking really bad. The starter is the largest current draw of the electrical system.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 10-19-2017, 09:09 AM
gtc gtc is offline
abides.
gtc's Avatar
Originally Posted by yelcab1 View Post
Simple, isn't it.
Yep!
Graham
1984 Carrera Targa
Old 10-19-2017, 10:15 AM
