Banned but not out, yet..
Fie on you good Kenik.
![]() For reasons unbeknownst yea I be in olde English mode, however since I most temporarily reside in Boston, where the British oppressors had their @$$e$ handed to them....
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 10-20-2017 at 05:28 PM.. |
Reiver
Yes, in the 82-83 models.
De Oppresso Liber Strength and Honor 5th Legion |
Two options for ya:
240 BHP on CIS (hi comp pistons and cams) Replacement CDI Unit 232 BHP on PMOs (no internal mods to engine required) https://www.impactbumpers.com/forum/index.php?/topic/30521-30-sc-with-pmo-carbs-and-cdi-dyno-plot/ The CIS route will be more 'streetable' but the PMOs more shouty!
www.classicretrofit.com |
What to do when CIS works perfectly?
PMO is also very streeable. My twin spark 3.2 short stroke puts out 283bhp and 345Nm with hot cams. It has a very flatt torque curve with 245Nm at the wheels at 2500rpm. and 293Nm at the wheels at 5180rpm. Costs a lot to build, but WHAT AN ENGINE, real hot in a 1200kg targa ![]() Ta
You could also use the 993SS camprofile. Gives even more grunt. Or you could "play" with advancing/retarding the 964 cam. One way gives more torque, the other more power. Think the 993SS is the hottest one when using original pistons. Sent from my iPhone using Tapatalk |
Reiver
Interesting options there....
I doubt I'd go back to carbs....FI throttle bodies would be more like it.
3 restos WIP = psycho
993SS and GT2 cams are the only common plenum cams I like. 993SS is actually pretty great.
Sent from my iPhone using Tapatalk Pro
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
^^ No doubt , PMO twin plug SS motors and FI throttle bodies make a powerful motor.
My impression was the OP was looking for a slightly 'easier' upgrade path. Might be wrong though.
Reiver
What, estimate as set up 220hp as a guess. What compression were you referring to Johhny as I've the 9.8-1 Euro now?
Of course Jonny my bad ![]() Then I can sum up the spec on my previous build: 3.0 SC Euro with 9.8:1 cr and 39mm intake ports. 964 cam, lift 1.35 at TDC 46mm PMO ITB Singelplug Electromotive Full sequential ECU SSI This setup was dynoed to 253bhp and 290Nm. on a Dynapack. Sent from my iPhone using Tapatalk Last edited by Litle brother; 10-21-2017 at 10:34 AM.. |
Reiver
That run down looks pretty damn nice.....
Fleabit peanut monkey
I did the volume calcs and it added 0.2 compression to my 9.3:1. Maybe you have 10:1?
1981 911SC Targa |
Reiver
No idea...I run 91 (only thing in Az) + an additive for higher octane and have never had an issue...but the engine does pull strongly from 3200...I'll call Howard up and ask about that...he did the work.
Guessing Howard knows a touch more than me.
1981 911SC Targa Last edited by Bob Kontak; 10-21-2017 at 02:47 PM.. |
Reiver
10 or close to it is the limit I'd say for 91....altho I do boost it as best I can....I had a 930-16 US 83 and you can def feel the dif in real terms.
