New-ish 911SC Targa Owner
Carrera 3.0 top end differences from SC
I'm trying to learn what might have be different on the carrera 3.0 to allow the 7200 revs.
As I understand it, the cams were the same and the valve size too. Anything else that mad 7200 safe for this motor compared to an SC?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
'76 & 77 C3 used the 2.7 crank and rods, same as the '72-73 911 2.4S & 911 2.7RS
Bill,
What did that do? From what I'm hearing they used 95mm pistons?
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
I don't beleive any CIS engine was reving to 7200.
A Carrea RS 3.0, which had the old S cams and a plunger type fuel injection. It would rev to 7200. I'm betting a Carrera 3.0 was redlined at 6300 like an SC. Jerry
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
max hp was 2000@6k max revs was 6800+/200 The bottom end is lighter than that used in the '78 up 3.0 SC's the 2.7 conrod bush is 25.99+/-1mm the SC 24.9+/-1mm 2.7 conrod bigend width is 23.75+/-5mm SC is 21.75+/5mm 2.7 conrod small end width is 25.01+/-1mm SC is 22.025+/.025mm 2.7 main bearings 56.990-56.971 SC 59.71-59.990 2.7 conrod 51.990-51.971 SC 54.971-54.990
you would lose that bet
Learn something new every day.
Inch by inch the Carrera 3.0 emerges as something unique versus its younger brother the SC. Thanks Bill!
In youthful enthusiasm, I replaced my stock rev-limiting rotor in my '76 2.7 liter (bone stock engine) with a 7300 rpm rotor from an earlier car. I would hit the rev limit coming out of turn 7 at Road Atlanta.
Was it a good idea? Doubtful. Did it do any harm? Nope.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
redline
Redline was 6800.Big difference was the crank weighed about 5 lbs.less so point A to B was quicker which is where most races are won.Ciao
Here is a pic of my 2.7L crank. notice the counterweights are thinner in addition to the smaller diameter journals.
![]() Here is a 3.0 crank for comparo: ![]() Thanks for the info Bill. I had seen 7200 mentioned elsewhere but I'll trust your 6800.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp Last edited by pampadori; 10-26-2017 at 08:27 AM.. |
Someone here did a 3.2SS engine with the C3 block. That thing must just SCREAM.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Reiver
The Euro 930-10 SC is also rated at 6800 +/- 200 rpm....at least for the 82/83 model years.
De Oppresso Liber Strength and Honor 5th Legion |
the interesting thing is the catless cars w/ that motor govern it w/ a distributor rotor which cuts the spark, just like the C3 the same year SCs which have cats govern the 6500+/- limit w/ a fuel pump cutoff
Funny everyone here seems to think a lighter crank enables higher revs?
Bland
In my 2.7 with webers, mod40 cams, 9.8:1 pistons, RS advance curve, I run to 7300. I made this change so I wouldn't have to shift to 3rd in the hairpin at a track I used to race it. It was worth about 2 seconds for me.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Bland
Bill - what direction does the rotor turn in a C3? Is it the same as a SC?
I guess I could just go check on my early Turbo 3.0
It rotates clockwise which would be opposite an SC motor
