Counterclockwise?
Can you open your door latch with the door open?
Maybe a stupid question but ....
With your door open, if you manually turn the latch to the closed position, can you pop the latch using either outside or inside door handles?
Doors are ripped apart and I'm chasing some issues.
Rod
Rod
1986 Carrera
2001 996TT
Old 10-31-2017, 12:19 PM
proporsche's Avatar
hi..very simple..unlock the locking rod(PULL IT UP) and now you can open from outside handle or inside pull handle
here
if you have central locking system in your 911 unlock your door with the key
Ivan
Old 10-31-2017, 12:31 PM
What issue are you chasing?
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 10-31-2017, 12:36 PM
Counterclockwise?
2 issues.
Passenger inside handle would not work and it felt like it was locked.
Drivers side would not lock with the key (central locking is working)
I took the latch apart on the passenger side and cleaned it up. It now works (no idea why) and you can unlatch it with the door open when you couldn't before using the outside handle.
Rod
1986 Carrera
2001 996TT
Old 10-31-2017, 02:04 PM
proporsche's Avatar
hi..it is possible that your door handle trigger sensor is either of or not working
number 5 on this pic
Old 10-31-2017, 02:27 PM
That's interesting. I have a brand new passenger side latch mechanism sitting at home because I had issues with mine, we can pull parts from it if you need it. I fixed mine, but my issue was my door kept popping open.
Sounds like you fixed some of it, what's not working at this point?
'66 912 - Polo Red;
Old 10-31-2017, 03:23 PM
Counterclockwise?
It appears to working, but now I have a broken #7 in your diagram. Where can I buy one of these? Do I need to replace the actuator? Grrr
I really need to know the answer to my original question ... please.
Old 10-31-2017, 04:24 PM
echecsqueen's Avatar
In my 1988 3.2 with central locks the answer is YES. With the door open you flip the catch with either the inner or outer handle.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-31-2017, 06:01 PM
needspeed's Avatar
Even if the door is locked (manually by turning the knob or pressing the central locking key button) or only when the doors are unlocked? I'm also chasing down central locking issues on my car.
Old 10-31-2017, 06:17 PM
When my door is open I am unable to actuate the lock by pressing the central lock or the lock button...it locks and then unlocks immediately ...like " click click" no pause.
If with my door open I flip the latch on the vertical part of the door, then either inside or outside handle will unlatch it.
Old 10-31-2017, 06:38 PM
Do you still have the alarm in the car? When I removed mine it does just what yours does. Looking for the fix myself.
Old 11-01-2017, 03:56 AM
proporsche's Avatar
911rod...you need to just replace the rod here is part number 964-537-571-00-M100
pelican part have it..
Ivan
Old 11-01-2017, 04:55 AM
Counterclockwise?
Thanks for all the help peoples.
I've ordered 2 new rods and will go back to tackling this.
Rod
1986 Carrera
2001 996TT
Old 11-01-2017, 08:11 AM
Counterclockwise?
Update. So much fun having a 31 year old car with 400,000 km.
Passenger side appears to be working fine now (would not open from the inside) after cleaning and lubing the latch and replacing the arm for the actuator. I haven't put the door card back on yet tho. Adjusting the actuator up or down relieves stress on the inside handle and makes it feel smoother.
The drivers side outdoor handle was opening the door when in the lock position and didn't work at all sometimes. Turns out the bushing in the latch mechanism has worn so the arm on the right in the picture is leaning out. Now it catches the arm to the left when locked and unlocks the car. When unlocked the one on the left goes back so the one on the right misses it all together hence leaving the outside handle inoperable.
Need new latch? Are we havng fun yet?
Rod
1986 Carrera
2001 996TT
Old 11-06-2017, 12:27 PM
proporsche's Avatar
Hi Rod have a look why is the latch in open position ,the spring should be far back to the left.
here
Old 11-06-2017, 12:34 PM
Counterclockwise?
Your pic doesn't work.
The spring on the left or right?
Rod
1986 Carrera
2001 996TT
Old 11-06-2017, 12:46 PM
