gt3racerich's Avatar
Source for wood shift knob bushing?
Does anyone know where I can purchase the insert or bushing that is required to install a wood shift knob on a stock 1973 911 shifter? I was given a nice wood knob as a gift but it is just a bare knob without any way to install it.
Thanks.
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant.
Old 11-04-2017, 12:46 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Arrow shift knob install - crush bushing
shift knob crush sleeve alternatives
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 11-04-2017, 09:07 PM
There was a thread I read on here just this week that talked about this .
If I recall , it was a European guy that made his own balsa gear-knob and ended up using epoxy to bong an insert in .
Old 11-04-2017, 09:09 PM
Flojo's Avatar
What diameter is there in the knob for a bushing?
The 915-shiftrod is 15mm, the G50 is 13mm with an M8 thread inside.
Maye show pictures and measurements of your knob for further help
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-05-2017, 03:15 AM
We have been making wooden gearknobs for a few years now.
We make an Aluminium sleeve with straight knurls which presses into the wood.
They have the same ID as the original gear lever and we use a short tolerance ring to hold them onto the shaft.
Old 11-05-2017, 05:00 AM
Thanks for the replies.
The opening in my knob is 14.44mm. I come up with a measurement for my shifter of 15.23mm.
Chris, what size is the opening in your knobs to accept the sleeve that you make?
I assume I would have to drill out the opening although I don't know how I would do that without damaging the wood. (that is if you would sell me one of your sleeves)
As Flojo says, the shifter for a G50 is 13mm. Maybe my knob is for that and I should try to sell it and get the correct knob?
Any other thoughts are appreciated.
Old 11-07-2017, 02:31 PM
universeman's Avatar
Why don’t you PM Chris and see if he’d make a deal with you on trading the knob you have, for one for your car
Old 11-08-2017, 01:18 AM
Flojo's Avatar
well, widening it is the easiest part. no?
widen the bore to16mm net and it should fit with crush sleeve like a charme.
Old 11-08-2017, 01:45 AM
My concern is trying to drill into a round object. I am afraid that I would have to put so much clamping force on it to hold it still while drilling that I could damage the knob.
I still would attempt it if I could source the correct bushing or collar.
I would certainly buy one from Chris if he would sell just a collar.
Old 11-09-2017, 05:21 AM
Chris, any chance I can purchase a collar from you?
Old 11-09-2017, 05:22 AM
