Schleprock
Souk,
It looks to me that VCI uses the "widget" spacer because of their 1-piece front rotor choice. The rotor they use is not a custom application. Their rotor is that from the '86 951. The 2-piece rotor method allows you to establish the necessary o/s with the rotor hat instead of the "widget" spacer? I'm sure Chris reminded you that you have to file the ball joint cup on the A-arm a tiny bit too. Even when the spacer's in there. I didn't like the spacer idea myself because of how the grease seal sticks out a bit. Just my opinion. Far be it from me to question VCI's design. It obviously works because Chris has no problems. Quote:
The caliper hole spacing is 3.5" O/C. That's why the holes are welded and redrilled for your 3" O/C spacing. See how the holes are further inboard to the caliper C/L? ![]() Bill, Could you point me/us to some references on brake sizing, biasing, design, etc? Seems like you have to repeat yourself so often regarding these issues. ![]()
Kevin L '86 Carrera "Larry" |
Schleprock
Somewhere in the Midwest
![]() Last edited by MotoSook; 02-03-2004 at 10:44 AM.. |
Schleprock
I'm assuming the front rotor choice by VCI was based on cost issues. I'd agree that the 951 rotor is cheaper than 2-piece. Can't make the kit cost too much I guess. Apparently their kit is a slight compromise in that sense? Not as much heat management as Bill's setup, but still an effective upgrade?
Moving the caliper via the axial-to-radial adapter still doesn't address the rotor interference with the ball joint cup on the control arm. Mark might have a used Carrera rotor for you. I can check today. If not you can borrow one of mine. I have take off the RR caliper anyway to replace a torn dust boot. Just so long as I get it back stickyfingers................ ![]() Pad area 964 4 piston calipers both F/R = 86 cm^2 Pad area 930 calipers = 94 cm^2 It appears that the fronts need the adaptors to get the caliper spaced radially outward far enough for rotor clearance? That's how I understand it from Bill's quote: Quote:
Sheesh go skiing for a few days and everyones shorts get knotted up.
CHP-POR Quote:
Schleprock
Souk,
Your quotes make my brain overheat like a 24mm front Carrera rotor under a 964 caliper.................... ![]()
Souk
Chris does not have this setup. He has the calipers modified by VCI for use with smaller 944 or 951 rotors. That was all he needed on his very light car. The 930 rotors are the ticket for heavier and or faster cars. the rotor steps are[list=1][*]282.5x20 &290x20 mostly thru '83[*]282.5x24 & 290x20[*]282.5x24 & 290x24 '84 htru '89[*]299x28 & 289x24 Chris' setup 944t rotors[*]304x32 & 309x28 930[*]322x32 & 322x28 993tt[/list=1]
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 02-03-2004 at 11:59 AM.. |
I don't know how to do it otherwise! Bill's back!!!!
SprintStar,
There are a whole bunch of issues w/ installing 930 brakes on a swb car first- the front struts need to have 3.5" ears second - Warren says that the trailing arm mounts are 2.5". I don't know if that is true or not but 930rear calipers require at least 3" mounts. Now I alway thought that was what was used on those cars but I have never worked on one so don't really know.
What's confiusing is that there are several possible ways to do this sort of thing. and the front and rear are different.
My head hurts as well.
Bill, I expected Kevin's pea brain to hurt, not your's
![]() OK! In a nut shell: In the front: I'm going to maching (or have VCI do it) 951 front calipers and make r-a adapters. I'll machine a spacer for the rotor too. Use 951 front rotors. In the rear: I'll hog out and make a filler "clam shell" for the rear calipers and use the 24mm Carrera rotors. I understand this is less desireable than the 930 rear rotor setup, but my car will not be a full track car. I won't have to machine the inner face of the calipers to fit the 28mm 930 rotors. Use my stock 19mm m/c. OK?! Approval:___________________ |
No matter what you will want a 23mm ATE m/c. Steve Weiner is a good source for these. You want the kit which includes the rod and fittings.
I know of no way to use the 944/964/993 Brembos in the back w/ the Carrera rotors. They are too small in diameter.
The redrilling method for use w/ 930 309x28s also moves the holes about as close to the top of the caliper as is practical. That means that 309mm is about the smallest diameter rotor that can be used in this way.
That (!) clears it up. Thank you once again Bill!
Super Moderator
Bill,
THere is actually abot 4mm of pad overhang with the 84-89 rear rotor... ...but while this is true, I have yet to find anything negative about it. (other than wasting 4mm of brake pad. ![]() I would have preferred thicker rear rotors since they are only 24mm but while I consider myself harder on brakes than your average bear, I have not had any overheating issues since installing the VCI kit. I have mixed feelings abotu the 23mm master cylinder though. 1) Since the sellers are re-selling it, they charge too much for what I know is a basic Mercedes truck m/c. I understand why, just don't like it. 2) The pedal is SO FIRM, that it makes it more difficult to modulate.
Sprint. |
