Another backup switch question
On a '76 911 I've taken the trans. support bracket off and am ready to remove the backup switch but the speedo cable connects right next to the switch. I can get a wrench in there but cannot move it because of the speedo connection.
For you guys who have done this job, did you guys undo the speedo connector?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
I don't know what a electric speedo looks like, all I can say is that in my situation, a cable runs adjacent to the backup switch that I am saying is the speedo cable. I can post a pic. if you like.
It's just that the '76 2.7 Carrera came w/ a 915/43 w/ the older style mechanical speedo the "76 Carrera 3.0 came w/ a 915/44 w/ electric speedo I had always assumed that all the '76 Carrera's used the same trans, I was wrong.
Here's a pic of my dilemma.
Pull the speedo cable then use a combination wrench to loosen the switch. Either open end or box.
Are you pulling the wires off of the switch with needle nose?
