-   -   1970 911T and intro thread (http://forums.pelicanparts.com/porsche-911-technical-forum/981672-1970-911t-intro-thread.html)
Sauceman 04-09-2018 07:01 PM
Thanks guys!
Having a hard time sourcing some parts. Like the throttle cross shaft ball stud that bolts to the right side carb, and a double groove pulley for the A/C.
Any help would be appreciated!
cheers
dafischer 04-09-2018 07:33 PM
I might have the throttle shaft mount. I'll check this weekend.
Sauceman 04-10-2018 04:15 AM
That would be awesome, thanks!
cheers
coldstart 04-10-2018 12:17 PM
Great build! I think I have the pulley plus I am in Ontario so their is no cross-border duty. I will check this week. I also have a set of SSI heat exchangers and other parts for sale if you are interested. Send me a message with your contact info.
I really enjoyed the write-up and the pictures. Keep up the good work! It is inspirational to me as another early targa owner.
Sauceman 04-10-2018 05:11 PM
Awesome thanks! PM sent
Well we got the cases split on the 2.2. Turns out we had 2 pistons seized in their bores preventing the crank to turn, but the oil pump was also seized up with gunk that we had to cut the oil pump drive shaft to be able to turn the crank for piston removal.
http://i140.photobucket.com/albums/r...psyf1tf2fw.jpg
http://i140.photobucket.com/albums/r...psydmccaxq.jpg
http://i140.photobucket.com/albums/r...psarnzgaea.jpg
http://i140.photobucket.com/albums/r...psqxpluics.jpg
Severed oil pump driveshaft,
http://i140.photobucket.com/albums/r...psoxa5zmqt.jpg
Crank bearings are in fantastic shape and the crank looks great so we got lucky there.
http://i140.photobucket.com/albums/r...psy60ljfgn.jpg
http://i140.photobucket.com/albums/r...psd4jetcuo.jpg
Boxes of stuff,
http://i140.photobucket.com/albums/r...psi1vc75a0.jpg
Oil pump,
http://i140.photobucket.com/albums/r...pske16dagy.jpg
http://i140.photobucket.com/albums/r...psatuzqx33.jpg
Fun stuff!
cheers
Sauceman 05-17-2018 05:45 PM
Well we got the body work all done and a shiny coat of blue!
http://i140.photobucket.com/albums/r...ps32x7s6mb.jpg
http://i140.photobucket.com/albums/r...psx1cq7f8h.jpg
http://i140.photobucket.com/albums/r...pspjkubshd.jpg
http://i140.photobucket.com/albums/r...psz8knwyzo.jpg
http://i140.photobucket.com/albums/r...ps4w4wyqef.jpg
Now we just need to finish putting the body panels on and give her a nice wet sand and polish!
cheers
Sauceman 03-06-2019 05:52 PM
Well we got the engine cases back from the machine shop. They installed new oil squirters, removed the oil passage plugs and cleaned out the entire cases and machined new plugs. They also repaired the one oil passage hole that was corroded straight through.
https://i140.photobucket.com/albums/...psgxccvsml.jpg
Now the pistons and cylinders going back in,
http://i140.photobucket.com/albums/r...psd593c6cv.jpg
Always check new parts, when we pulled the pistons out of the jugs ALL the ring gaps were in a straight line lol.
http://i140.photobucket.com/albums/r...psaee0e636.jpg
http://i140.photobucket.com/albums/r...psmfgtikp7.jpg
http://i140.photobucket.com/albums/r...psmkgdjqax.jpg
Even got some paint on the covers,
http://i140.photobucket.com/albums/r...ps52npsogi.jpg
cheers
valveandpiston 03-07-2019 04:29 PM
Is this the world's fastest restoration?
Sauceman 03-19-2019 03:32 AM
Well it's been over a year lol!
cheers
hughc 03-19-2019 03:46 AM
I agree. There has been a tremendous amount of work done in that short period. Very encouraging.
Derek77 03-19-2019 10:37 AM
Sauceman, where is your shop located? Nice work!
RWebb 03-19-2019 06:10 PM
re welding
- the car can be considerably stiffened if extra welds are added - also Dave at TRE knows how to weld in some extra metal to really stiffen the car; may work for a targa - I'm not sure
enjoy the wonderful road racing pattern shifter...
Sauceman 03-19-2019 06:16 PM
Thanks,
We are located in Napanee, Ontario Canada.
cheers
Sauceman 05-04-2019 05:54 AM
Got some more details done,
Took apart the gauges and detailed them, the outside bezels were corroded so now they are GTG!
https://i140.photobucket.com/albums/...psd0zyfr4e.jpg
https://i140.photobucket.com/albums/...psnucphswb.jpg
https://i140.photobucket.com/albums/...psd0zyfr4e.jpgL]
Yes even the clock works lol!
Cleaned up the pedals,
https://i140.photobucket.com/albums/...psqpbynr8o.jpg
Shifter plate,
https://i140.photobucket.com/albums/...psxrmgfumj.jpg
And the park brake assembly,
https://i140.photobucket.com/albums/...psj7dlbj2i.jpg
And we fixed the cracks in the dash pad,
https://i140.photobucket.com/albums/...psmr9xglim.jpg
cheers
RWebb 05-04-2019 05:36 PM
what filler did you use to fix the cracks in the dash pad?
Sauceman 05-05-2019 01:19 PM
A company called FibreNew in Belleville came over and fixed it. Not sure what product they used.
cheers
Sauceman 05-15-2019 03:22 AM
Well we got most of the engine back together, no issues
https://i140.photobucket.com/albums/...psaodjn0rw.jpg
https://i140.photobucket.com/albums/...psifnpsww5.jpg
https://i140.photobucket.com/albums/...psfon1qmxs.jpg
https://i140.photobucket.com/albums/...psjqcntzly.jpg
https://i140.photobucket.com/albums/...psq8826ant.jpg
https://i140.photobucket.com/albums/...psgortik0a.jpg
https://i140.photobucket.com/albums/...pslr5ipteu.jpg
And we got the first cut of polish done on the paint :)
https://i140.photobucket.com/albums/...psto7vhcqa.jpg
cheers
Sauceman 10-18-2020 07:27 AM
Well after a long time to get parts shipped we are back at the 911!
Getting a lot of fidly bits done like shifter and throttle rods in place before the engine goes back in.
http://forums.pelicanparts.com/uploa...1603031107.jpg
Looking through the parts manual I'm having trouble finding out which fittings I need.
There are the ones for the two small oil lines here,
http://forums.pelicanparts.com/uploa...1603031183.jpg
And what goes into this hole here beside the oil thermostat,
http://forums.pelicanparts.com/uploa...1603031220.jpg
Thanks again for helping out this Porsche newb!
cheers
Trackrash 10-19-2020 12:30 PM
That is for the oil pressure sender. That is assuming you have the gauge for oil pressure , as some cars just had a warning light.
Sauceman 10-19-2020 06:18 PM
Awesome thanks, yes it has a gauge so I will order the sending unit for it.
Thanks!
