Correct part number for 3.2 throttle bellcrank
Pet says this # 911.110.091.07
I have this... ![]() Does the bellcrank change between CIS and DME transition? Speedo |
gearhead
Casting number versus part number. That's the correct part for the 3.2 with DME. CIS cars don't have it.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I'm confused why the casting # would not be the same as the part#
David |
The biggest difference over the years was going from nylon bushings to brass and extending the spacer to the casting on the rear stud in the mid 80s.
Bruce |
Member 911 Anonymous
Actually those bushings on that component is quite different in that it has a teflon like coating and is steel. It even comes in a vacuum sealed packaging.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
