Transmission oil question
I am fairly new here to pelican and had a question on transmission oil.
84 targa with a slight difficulty shifting to 2nd. I am taking the advise of some members here and will replace my transmission oil since I recently purchased the car.
I was going to put in Kendall but wasn’t sure if I had a lsd on the 915 transmission. Was the 86 targa 915 a lsd transmission? Would it be safe to put the Kendall with lsd additive or just straight 80/90?
Old 01-03-2018, 05:24 PM
disband
juanbenae's Avatar
jack the car up, spin one rear wheel & if the other spins the same direction you likely have an limited slip. or just put swepco in and know you're good shape with both applications.
Old 01-03-2018, 05:30 PM
Did you get the memo?
onewhippedpuppy's Avatar
Another vote for Swepco here. But the single best improvement that I have made to my 915 was a full JWest Rennshift kit. Now it’s easy enough that my wife can drive my SC without issue.
‘07 Mazda RX8-8
Old 01-03-2018, 05:56 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It wont matter what type of gear lube you put in, as long as it is conventional gear lube not synthetic.
I prefer Kendall myself.
Your issue will most likely be worn Synchros. Here is a test, Double Clutch, I bet your 2nd will be allot easier to get into. The double clutch method will help slow down the worn synchros so you can mesh into gear allot easier. This will also lengthen the time needed before a gear box rebuild is required.
+1, to check for LSD, raise rear end safely and turn the wheel.
'85 Carrera Targa
PCA/POC
Old 01-03-2018, 07:10 PM
evan9eleven's Avatar
Good advice here. Get the rear end safely in the air and spin a wheel as the other guys suggest. If they both go the same direction you have an LSD. If the other side turns the opposite direction then you have a regular diff. Unless I'm mistaken a LSD was an option.
As Draco says, run a non-synthetic gear oil. I run Kendall. The PO had Mobil1 synthetic in the box and the shifting was crap. The dinosaur oil helped me a lot, but if your gearbox is worn the oil change won't fix it, but may make it a bit more tolerable depending on what oil is in there now. Good luck!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 01-05-2018, 10:36 AM
Bill Verburg's Avatar
'84 US 3.2 Carrera had a 915/68 trans. These are made by ZF and LSD was an option, The wheel test is one way to tell, but if the lsd is worn(very likely) it's not definitive
Better to look at the bottom of the trans
this is a 915/73 serial # 74F 03454, the 12 between the 73 ans 74 means in was originally built w/ an lsd
This is a 915/63 serial # 74C 2459, not 12 means no lsd
JMO and what I use Swepco 201 for a 915 w/ or w/o lsd all environments, Delvac for G50(track use)
Bill Verburg
Old 01-05-2018, 12:16 PM
proporsche's Avatar
My thumbs up for Swepco 201
Ivan
Old 01-05-2018, 12:51 PM
gearhead
Which Kendall are you guys using?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-05-2018, 01:08 PM
Kendall 80/90 gl5 with LSD added.
Old 01-05-2018, 02:45 PM
According to Zimmerman, the lsd additive does not hurt even in non LSD trans.
Old 01-05-2018, 02:46 PM
Kendall.
206 637 4071
Old 01-05-2018, 03:11 PM
gearhead
Which one?
1974 914 Bumble Bee
2009 Outback XT
Old 01-05-2018, 03:59 PM
SoCalSK8r's Avatar
I use the same and have been happy with it, my 915 shifts very nice but then again it only has 60k miles.....
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 01-05-2018, 04:12 PM
81SC's Avatar
Originally Posted by Matt Monson View Post
Which one?
This is the one I purchase through Amazon.
81SC Coupe
Tony Kart/Yamaha
Old 01-05-2018, 05:43 PM
San Diego, CA
So just what is the difference between the Swepco and Kendall? I installed the Swepco on my 77 and noticed an improvement. Never tried the Kendall.
For a 915 box, Is the difference subjective like a Coke or Pepsi preference?
Old 01-05-2018, 07:51 PM
John Walker told me he thinks the Swepco oil is too slippery for a 915 and might make synchro issues worse. This makes some sense as the synchro is a friction ring.
Old 01-05-2018, 10:33 PM
Having recently changed from Swepco 80w-90 to Kendall 80w-90, the noticeable difference is the shifting when the transmission is cold. It now shifts very well when cold, and it didn't before.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 01-06-2018, 08:45 AM
BINGO!!! Tim
Old 01-06-2018, 09:36 AM
