Send a message via AIM to EPorsche
Thermostat Opening
At what temperature does the non engine oil thermostat open? I have an aftermarket 180 degree mocal one. Thinking about going to a 203 degree one.
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 01-16-2018, 03:48 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
T-Stat.
Why?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-16-2018, 04:18 PM
More Likeable IRL
juanbenae's Avatar
trump voter perhaps?
Old 01-16-2018, 04:35 PM
Bill Verburg's Avatar
Both t-stats open at the same temp, the melting point of the paraffin working medium in them
182-189°F
83-87°C
Bill Verburg
Old 01-16-2018, 04:37 PM
Right now my car oil temp is 170-180 deg winter or summer. At that temp its hard for water to boil off. What do you think Bill?
'81 911SC stock
Old 01-16-2018, 05:05 PM
Therm
I remember the engine cooler tstat opening at 180 deg. And the front cooler at 210 deg
Doesn’t make sense for both to be 180
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-16-2018, 05:17 PM
Engine and auxiliary thermostats........
Mike Bruns
Mike,
Sorry. I hate to disagree with you. But I have done a lot of testing and investigation about this subject. Both the engine and auxiliary thermostats operate at similar temperature. At 185°F, the slide valve starts to open and fully opened by 200°F.
Test the thermostats side by side in an oil or weather bath and you will observe their identical thermal behavior.
Tony
Old 01-16-2018, 06:08 PM
That’s good enough for me Tony, I see you have a lot of subjects to test !
Mike Bruns
Old 01-16-2018, 06:22 PM
Given Tony's experience and testing of these thermostats, my first suggestion to the OP is to test his Mocal thermostat and verify the temperatures it begins to open and, eventually, fully open. If it does not fall within the range that Tony and Bill have found to be correct--~185* through ~200*--then he should not use it. If the Mocal does, in fact, open at 180*, then it would be opening before the on-engine thermostat, effectively overriding its function. This would be consistent with the low oil temps the OP records.
IMO, testing of the Mocal is in order.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-17-2018, 06:57 AM
Mike Bruns
Sure it does, they both are the same design using the same components. The working medium is a paraffin wax that has a fixed melting point which starts the t-stat opening process.
The engine one opens first(at a lower oil temp) because it see's the hotter oil first.
the temp rise curve has a small plateau between the engine t-stat opening and the wheel well opening,
The oil temp rise curve looks like this
Bill Verburg
Old 01-17-2018, 07:19 AM
T'stat
Great info guys Thanks
Mike Bruns
Old 01-17-2018, 08:53 AM
It's a 914 ...
stownsen914's Avatar
To the comment from the OP about needing to boil water off, a couple comments.
The "spent" oil in your engine crankcase will be substantially hotter than what your gauge says. After the oil has done its work in the bearings, etc and spills into the bottom of the crankcase, it should be well over 200 degrees (once the engine is warmed up) even if your gauge shows less than 200, and should be hot enough to evaporate water off.
And even if the oil never reaches 210 degrees inside your engine for some reason, water will still evaporate off and out the breather hose from the hot, aerated oil in the crankcase.
Scott
Old 01-17-2018, 09:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Frank shared with the forum awhile back the similarity of the internal vs. external t-stat. The only difference is the height of the windows on the regulator body itself (Frank refers to it as the piston) and so the actual thermal regulator unit is the same within the two
internal oil thermostat repair
Kevin L
'86 Carrera "Larry"
Old 01-17-2018, 10:51 AM
