Brian Minson's Avatar
Heater paper tubes
My '67 coupe is missing the paper tubes that connect the heat exchanger's to the heater boxes. I ordered two of the URO tubes (Pelican Part No. 930-211-622-01-M253) and they are the same diameter as the both the exchanger and heater box! Is there an inner sleeve I am missing or what?
Brian
Old 01-20-2018, 02:33 PM
douglas bray's Avatar
Google aircraft spruce . You didn't get that from me though
Old 01-20-2018, 02:48 PM
Earthling
Brian Cameron's Avatar
You tallkin about SCEET?
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 01-20-2018, 09:21 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
paper tube.
pm Kuehl on this forum.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-21-2018, 07:36 AM
+++++ a good solution
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-21-2018, 07:33 PM
Guardsred911's Avatar
SCEET or SCAT from aircraft spruce or amazon. Working on mine yesterday.
J
911 SC - 1980
911 S - 1977
Old 01-21-2018, 07:36 PM
Thanks for the great source. I am currently looking to replace mine. Does anyone have the correct diameter for a 71 911 and the total length to order to replace all tubes?
Old 01-22-2018, 09:46 AM
All the 911/930 up to the SC use 60mm ID hoses of varying lengths and colors: brown, black, tan
Best trick is to buy the longest hose 911 211 522 01 (1100mm) then cut it to length.
Its cheaper than buying all the shorter pre-cut sections.
Old 01-22-2018, 01:24 PM
Presuming the above is correct in that all the hoses are the same over the years, I dug up my old invoice from Aircraft Spruce - order this in your desired length:
05-30610 SCEET-10 DUCTING 2 1/2"
Old 01-22-2018, 04:28 PM
The opening on the heater boxes on my '67 are 60mm the same as the hose... shouldn't the hose be a bit larger to slide over the box, and allow a the clamp to secure it???
Brian
Old 01-22-2018, 04:48 PM
Hi Brian my experience has shown most heater parts have been around for some time and the tubes tend to get out of round over the years making getting the hoses on a challenge.
All the factory parts I've used are a tight fit but the hoses do fit. Check for distortions in the metal tube first.
Old 01-23-2018, 07:57 AM
