LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Super cool and at the sharp end of the stuff we get to read about here. John.
Old 07-31-2018, 10:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
DHE11's Avatar
Thanks John,
Im fortunate that the sale of my previous car went a long way towards funding this build!!!
I started with a relatively cheap chassis and engine which hadn't been run for many years, which meant I could spend my budget (and some) on the good bits that will translate to performance.
The only area I'm loosing is this car won't be road registered, due to the full cage and amount of modifications... on the upside it will get used nearly as much as designed to run in many different types of events (except cars and coffee!)
77’ 911 Karminrot
Build Thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/985164-project-77-new-build.html
Old 07-31-2018, 01:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Eric at Pelican Parts's Avatar
Originally Posted by DHE11 View Post
Yes Eric,
Has progressed well over the past few weeks, and its now at the the stage of assembling lots of parts from various suppliers, so there has been a bit of “fitting” involved.
I think when you called by the shop we were talking about changing crank pulleys as PO had installed a smaller lower pulley.
Slower fan speed = higher CHT = knock sensor/timing = less power ��
So decison was to change lower pulley, then enging frame and carrier brackets didnt fit the larger pulley, so new frame etc etc... Some Rothsport parts got ordered/delviered and problem solved ��
I've got some free time this weekend, maybe I'll swing by to say hi to Tyson and check on your car! Man, Tyson did some awesome work to get your clearance back and it seems like you'll have ample clearance going back to 235 or 245's. Really enjoying the updates. It's on the home stretch now, so it seems like you're coming back sometime in the next few weeks?
23 Macan GTS
97 240SX
94 Land Cruiser
Too many Miata's to count.
Old 08-01-2018, 03:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
DHE11's Avatar
Yes, planning to be back end August/September...
Look forward to catching up again then.
Still a lot to set up and complete, things like lexan, shifter/handbrake, wiring etc but the big bits are now falling into place.
Agree, the build and custom fabrication is in great hands with Tyson
77’ 911 Karminrot
Build Thread:
Old 08-03-2018, 03:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
DHE11's Avatar
Recent activity has been installing wiring and making new oil lines etc.
Getting close now to giving it a start (has been a a while since it last ran!)
New front oil cooler and hoses installed...
77’ 911 Karminrot
Build Thread:
Old 08-17-2018, 05:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
DHE11's Avatar
Hargett shifter and Voodoo 13 Hydro installed.
Just need to get some flex hoses to connect the handbrake as expect the location may need some fine tuning later. Also allows for it to be removed if it gets in the way on track...
77’ 911 Karminrot
Build Thread:
Old 08-18-2018, 09:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
DHE11's Avatar
Closer to running... but in another case of “while your at it” removed the old coils and converted to fit new 993 coil packs.
77’ 911 Karminrot
Build Thread:
Old 08-20-2018, 05:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
DHE11's Avatar
Update time!
More wiring and finishing touches... as the chassis has been sitting for a many years, Tyson ran into a few electrical gremlins on power up which needed relays and fuel pump etc replaced.
Gauges and dash in, and finishing more wiring...
Brakes bled, and line lock and hydro connected with flex lines but not secured yet. This will allow the position to be optimised later to suit seat and cockpit layout.
77’ 911 Karminrot
Build Thread:
Old 09-21-2018, 06:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
The races and events you'll be running...what sort of duration? As in, how many hours will you be in the seat for the longest events? Best, John
Old 09-21-2018, 06:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
DHE11's Avatar
Typically 20mins sprints is the most at club and state level.
The longest single stint i have done in my previous 911 track car was 1hr15min run in a teams 6hr endurance event at Wakefield Park (and that was in the rain!), and an hour event at Phillip Island.
This is being set up as a “multi tool” to do sprint, autocross, hillclimb and maybe some rally.
I would like to be able to do more individual or team style endurance style events in the future, so the larger fuel cell may come in handy! (I did think about changing for a smaller cell to save weight but left in the 27gal for maximum flexibility)
77’ 911 Karminrot
Build Thread:
Old 09-21-2018, 09:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
DHE11's Avatar
GT3 style ducktail fitted...
77’ 911 Karminrot
Build Thread:
Old 09-22-2018, 02:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Would you mind telling me what brand rear fiberglass fenders you used on your car? They look like they fit very good and I'm looking for a set to mount to my car currently.
Thank you
1975 911 race car build in progress
Old 09-23-2018, 08:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Cory M's Avatar
Thank you
I actually sold those fiberglass quarter panels to the previous owner. I've got more, send me a PM if you are interested. I'm in San Diego.
Old 09-24-2018, 05:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
DHE11's Avatar
Good to know Cory if i ever need spares
(Although, hopefully not soon...)
77’ 911 Karminrot
Build Thread:
Old 09-24-2018, 03:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Cory M's Avatar
Hopefully not!
Old 09-25-2018, 07:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
DHE11's Avatar
After some long days with final prep its ready to run...
Managed to squeeze in some testing today!
Had a run with Jack to see the track and find out how fast a 911 can go round Willow?
Answer is even on old tyres and a hot day, much faster than it looks in his videos.
The new motor ran great straight out of the trailer and was able to do a few quick laps before some hydraulic issues with the rear brakes grabbing needed attention.
77’ 911 Karminrot
Build Thread:
Old 09-26-2018, 08:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Cory M's Avatar
Congrats!
Old 09-26-2018, 09:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
DHE11's Avatar
After 11months of build, here are some of the suspension, brake parts and shifter parts which were left over...
I will be listing for sale on the main thread and as I’m not going to be here to mange it, need to sell it all together.
Talked with the guys at the shop and USD1,500 for the lot (pick up Burbank, CA)
77’ 911 Karminrot
Build Thread:
Old 09-28-2018, 12:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
DHE11's Avatar
Tried out some “protect n peel” before heading out to Willow.
Don’t have this in Australia so wanted to give it a go. Put on a coat the night before using a 2” disposable brush. The recommended little roller and tray might have been good for larger surfaces, and if your looking for a better finish, but for the front and around the lights and bumper the brush worked great.
The picture below is about 5mins after a rushed second coat prior to loading in the trailer. You can see its already drying and turning clear, has similar characteristics to PVA wood glue.
I ran the first coat up higher above the latch pins. You can just see in the sun the line between the headlights. Unless your up close, you can barely see my brush strokes.
I also did some on the side sills and rear wheel arches and will leave it on for the sea container trip home.
Its much less work that doing the blue tape thing!
77’ 911 Karminrot
Build Thread:
Old 10-01-2018, 02:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
scumbag
looks a fair bit better as well.
congrats on testing and preparing for the journey home!
can't wait to see some video of this monster on track.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 10-02-2018, 04:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
