-   -   Project 77 - new build (http://forums.pelicanparts.com/porsche-911-technical-forum/985164-project-77-new-build.html)
chrisbalich 06-20-2018 04:55 AM
i get so excited when you update this thread. i love this build.
R lights because of the weight? functionality? or aesthetic?
Mothy 06-20-2018 06:27 AM
Doing the same lights for mine.
I like the idea of LED units instead of the old Hella’s
Where did you get the light units?
DHE11 06-20-2018 11:47 AM
Thanks Chris,
The lights actually came on the car.
I decided to keep them as it fitted in with the weight reduction mission, and they have grown on me and now I’m “sort of” continuing the R theme with the front.
Got some covers to replace the front light assemblies (removed more weight) and gets a functional brake vent hole similar to the 911R front end...
http://forums.pelicanparts.com/uploa...1529520099.jpg
chrisbalich 06-20-2018 12:17 PM
as you approach completion, what do you think race weight will be?
DHE11 06-20-2018 12:53 PM
Took some more weight out with 935 front suspension, poly windscreen and wheels.
Put some more back in with extra roll cage bars for chassis stiffness and safety, and some rear suspensions mods and bracing.
Expect wet with driver and maybe some driver cooling gear around 2400lbs
(Or less....)
chrisbalich 06-21-2018 04:52 AM
(Or less....)
2400 wet with a driver is going to be a proper weapon. holy cow.
DHE11 06-21-2018 05:27 AM
Fitting the front signal cover / vent.
I had some blanks but they were only half the length covering the indicator void, and I then still needed to buy the horn grille cover, or make up some mesh grille.
So found these, and like all fibreglass parts required some cutting and modification!
It’s really never ending.... but I keep reminding myself, be patient, just do it once the way you want it now, and will be better than changing it later.
http://forums.pelicanparts.com/uploa...1529583573.jpg
DHE11 06-21-2018 03:06 PM
Some of the larger body parts now fitted...
While a little harsh on the eyes in full sun, pleased to see the lines of the car still show up, and are not totally dominated by the colour.
http://forums.pelicanparts.com/uploa...1529618141.jpg
http://forums.pelicanparts.com/uploa...1529618296.jpg
Eric at Pelican Parts 06-21-2018 03:20 PM
Looks good!!! Glad to see the updates and that it's coming along together quite nicely! Did you get the wing all figured out already too?
DHE11 06-21-2018 04:45 PM
Hi Eric,
Yes, after doing research and comparisons, decided to go with with APR wing pictured below.
Spec’d the attach spacing so ill be able to run on my new GT3 style duck tail, or the RS3.8 tailbase.
APR are making the wing now, and I plan meet KC and pick up early July
http://forums.pelicanparts.com/uploa...1529620586.png
Will do my own testing, but expect the GT3 style duck tail to be the go to set up on the high speed circuits with lower drag penalty.
Looking forward to getting back to Bathurst and our new track at Tailem Bend to test....
http://forums.pelicanparts.com/uploa...1529624157.jpg
Pfitz911 06-21-2018 08:48 PM
Hey mate
Forgot to tell you I’m in the US at the moment
I’ll get that booster back in a couple weeks...
Man that car is PINK!!! 😎
Eric at Pelican Parts 06-22-2018 03:28 PM
Awesome news! Does this mean you're going to be running two different sets of uprights, and at different heights?
Let me know when you figure out the dates you'll be out here again, I'll make plans to meet up with you!
DHE11 06-22-2018 03:54 PM
Yes Eric,
Two tailbases and two sets of uprights.
Have run a widebody with RS3.8 tail on the previous car with a much smaller wing element.
The challenge on this car will be balancing the front with more rear aero.
For low speed events like club motorkhana's I can remove wing entirety and just run the duck tail.
DHE11 06-22-2018 03:55 PM
Yes Eric,
DHE11 06-22-2018 04:08 PM
Originally Posted by Pfitz911 (Post 10081728)
Hey mate
Yeah, it's pretty bright...
(You'll be able to come see it in person in a few months...)
DHE11 06-24-2018 05:34 AM
Some boxes arrived this week!!!
New wheels... Light and wide @ 15-17lbs for 17"s
http://forums.pelicanparts.com/uploa...1529841795.jpg
Thanks to Ryan @ Jongbloed who made a very light set of wheels for me.
Was a bit of planning involved, and by knowing more about the car, its weight and how it was going to be used, we could optimize a wheel that would be super light, but importantly still be strong and reliable on track.
Ended up going with an aero series wheel with a smaller centre and stepped barrel which helped keep the weight down and saves well over 12lbs of rotating mass for the set.
The front and rear look a different colour in the photo below, but it's just reflection, they are both anodised black (paint's too heavy)
http://forums.pelicanparts.com/uploa...1529842132.jpg
LJ851 06-24-2018 05:03 PM
Those wheels are HOT !!!
DHE11 06-25-2018 06:12 AM
Knowing I was chasing weight, Jongbloed built the wheels with all titanium hardware... saved nearly a pound per wheel replacing the standard ARP fasteners!
puddy 06-25-2018 06:59 AM
Wow thats a bold colour, cant wait to see if finished and those wheels are awesome!
chrisbalich 06-25-2018 07:49 AM
this is the kind of stuff that makes my day to read. attention to detail and commitment to excellence.
