-   -   Project 77 - new build (http://forums.pelicanparts.com/porsche-911-technical-forum/985164-project-77-new-build.html)
nathanbs 07-08-2018 08:25 AM
Looking good. Can’t wait to see it around
DHE11 07-09-2018 05:05 AM
Quite a few updates and pics from time in LA last week.
Positioned rear brakes/lines as Tyson needed to weld in new brake line mount tabs which were removed while modifying the trailing arm attach points.
http://forums.pelicanparts.com/uploa...1531137694.jpg
DHE11 07-09-2018 05:33 AM
While the chassis is back at ProMotorsports being built, some finishing touches still taking place to the front bars and various small parts.
The large painted bar will pair with a flat floor and splitter.
http://forums.pelicanparts.com/uploa...1531138910.jpg
The smaller bar in grey primer has been fitted and prepped for paint this week. It will be used for Motorkhana/hillclimbs etc, or any other tracks where i need more ground clearance!
http://forums.pelicanparts.com/uploa...1531139006.jpg
http://forums.pelicanparts.com/uploa...1531139088.jpg
DHE11 07-10-2018 05:41 AM
Old wing - new wing!
This carbon banana wing will be removed and sold to make way for the new one...
This came fitted on car but I already have a similar one in Australia so don't need two of the same!
http://forums.pelicanparts.com/uploa...1531225601.jpg
Just picked up the new 71" APR which will go on.
Barely fitted in the rental car even with the rear seats folded down.
http://forums.pelicanparts.com/uploa...1531225941.jpg
DHE11 07-10-2018 05:51 AM
While at the APR office/warehouse I was able to talk with the guys and see how they are made.
The section below shows the two bonded carbon ribs (no aluminiuim spar required)
By using vacuum formed pre preg they can make these very light and strong.
http://forums.pelicanparts.com/uploa...1531226880.png
chrisbalich 07-10-2018 06:28 AM
71" is a huge wing.
i'm still learning 911 aero. will you be able to run a large enough splitter up front to balance the car? (without looking like a WTAC car or a transformer)
seems like a ton of rear downforce/negative lift.
Eric at Pelican Parts 07-10-2018 10:21 AM
It was great meeting with you and Tyson briefly! I'm looking forward to seeing Project 77's completion :) I'll swing by and pay Tyson a visit sometime while your car gets completed, Darien. I'll bring my real camera next time we meet too. See you again soon!
DHE11 07-10-2018 03:38 PM
Originally Posted by chrisbalich (Post 10102218)
71" is a huge wing.
Hey I’m learning too, and experimenting with set up is half the fun...
While this wing has potential to produce huge downforce numbers, can run at very low AoA and not get much of a drag penalty as its about 8:1 L/D ratio. Will do some real world testing, but should actually clean up the flow at the rear of the car and not increase the drag vs standard with no wing (while getting some benefits for neg lift and high speed stability)
or
if I’m lucky (and theory convertes to actual) could even improve drag and generate a faster top speed...
Will need to run it and test. Agree the front is more challenging to balance but found on previous car its amazing what fitting a flat floor does when combined with a decent splitter. So no current plan to have canards etc and look like a WTAC car.
Ill post the data for this particular wing. Recall 60-120mph at zero AoA its only producing 50-100lbs of downforce and wing drag penalty was like 10lbs or less.
DHE11 07-10-2018 04:02 PM
Originally Posted by DHE11 (Post 10102837)
Hey I知 learning too, and experimenting with set up is half the fun...
or
if I知 lucky (and theory convertes to actual) could even improve drag and generate a faster top speed...
From ARP痴 website for the GT250 wing
http://forums.pelicanparts.com/uploa...1531263582.jpg
http://forums.pelicanparts.com/uploa...1531263598.png
DHE11 07-10-2018 08:52 PM
More parts going back on...
Fuel cell fitted after getting recertified and fitted with a new bladder.
http://forums.pelicanparts.com/uploa...1531280480.jpg
http://forums.pelicanparts.com/uploa...1531280593.jpg
DHE11 07-11-2018 05:33 AM
Also managed to get seat position set up while in LA.
http://forums.pelicanparts.com/uploa...1531312128.jpg
http://forums.pelicanparts.com/uploa...1531312194.jpg
Running a 95mm dish wheel so removed the standard Momo and fitted my short NRG adapter.
http://forums.pelicanparts.com/uploa...1531312261.jpg
http://forums.pelicanparts.com/uploa...1531312281.png
chrisbalich 07-11-2018 05:36 AM
or
i always forget how much of an effect a flat floor can have as i've never had a car with one. the numbers on that wing with a low AoA are awesome....and with a high AoA, huge!
i'm excited to see how this car develops as you get it on track!
DHE11 07-12-2018 06:12 AM
Talking with the guys from APR, this is like their 3rd gen wing profile and developed with full CFD, hence the great L/D figures.
Lots of wings out there but i was looking for specifically one with low drag. The car is being built light, but it won't be big HP (just a 964 spec 3.6)
Most of the effort and development is going into the suspension/handling.
Plan to run this wing on the GT3 style ducktail (below from GT racing) which has now finished prep and paint ready to test fit.
http://forums.pelicanparts.com/uploa...1531400441.jpg
chrisbalich 07-12-2018 06:53 AM
this makes me happy. it's how i'm building my streetcar...albeit with an SC 3.0 motor instead of a 3.6.
power doesn't fix everything the way a lot of manufacturers and enthusiasts would have you believe.
puddy 07-12-2018 07:06 AM
So are you running a full carbon decklid & wing? If so do you have a rough weight of it?
I was thinking about upgrading my HEAVY GT2 style wing & steel decklid to full Carbon and adding extensions on the wing like yours, so I can see out the rear window!
Cory M 07-12-2018 10:28 AM
What's the plan for headlights? Noticed you don't have buckets in the fenders. Just going to use covers?
Cory M 07-12-2018 10:34 AM
That's how all my track cars have been: low weight and relatively low power. It really is track dependent though. I was racing in a Weight/HP class and on the technical tracks the light cars had the edge, but the faster tracks with long straights and hills the newer heavier cars had a big advantage.
DHE11- you should shake it down at a POC event before shipping it across the ocean.
DHE11 07-13-2018 03:36 AM
Yes, figure i will always find someone with more horsepower (or a newer car ) that can go faster in a straight line.
DHE11 07-13-2018 03:44 AM
Yes, the wing is full carbon construction. The airfoil section itself is very light, probably a few pounds (i haven稚 weighed it) The deck lid is fibreglass, which is much lighter than steel. Not enough gains for the extra expense in going for full carbon for the decklid.
I spent that money where it matters more on the suspension and lighter wheels.
DHE11 07-13-2018 04:03 AM
For most of the time will be fitting covers.
http://forums.pelicanparts.com/uploa...1531479501.jpg
I am actually going to look for some buckets and fit some headlights for night or rally events where i need them. I beleive aftermarket Jeep LED lamps are the same size and fit VW beetle /early Porsche ok (and are about 1/10th the price ive seen for the Porsche LED retrofit options)
If anyone has any spare headlight buckets and rings, please let me know as I知 interested...
