which collet stud remover tool do I need?
I noticed a couple of different ones listed on our host.
I've been told to get the Snap On tool to remove my studs from the case. Can someone please verify exactly which tool I need? Also... can I use this same tool to reinstall my studs or a set of ARP studs?
1987 Porsche 911 Carrera Coupe |
Under the radar
Just double nut the studs and use a propane torch to melt the glue that holds the studs in the case. As soon as the old thread locker melts the studs will come right out.
You then should carefully clean the threads in the case before reinstalling your new studs.
double nut worked for me too
hi boys.i have been using for most of my 911 mechanic live Stahlville company tools stud remover.
Snap on tools are my primer tools and always been among USAG tools. For the removal Snap on and Stahlville have the best products. here https://www.stahlwilletools.com/ Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Double-nutting is best if it works because it will not damage the stud's threads. Heat is your friend. Doesn't always work, though, if there is a lot of corrosion.
In which case, a stud remover may be needed. I have a set from AST, but I think that any reputable tool maker's version will be a fine option. Depending on how smooshed the threads get, you may need to replace the stud. Good luck!
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
I have one of these, but I haven't used it on anything yet:
https://www.amazon.com/gp/product/B00265M8N4/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 Mark
1979 911SC Targa |
Marks link is the one I use. It’s manual tool but works on the impact.
Bruce |
The 9 Store
2-3 minutes with map gas and most studs will come out very easy. I know some guys do it without the gas but I don't know why. It requires way more torque without heat.
All used parts sold as is. |
Schleprock
The Snap On collet style tool works fantastic. It works better than double nutting because it doesn't rely on the thread interference that double nutting creates. The collet tool works via a wedging action within the tool. The interior of the tool body and the exterior of the inner collet have a tapered shape that causes the collet to be squeezed very tightly around the threads. So the collet basically grabs the stud like a vise with matching threaded jaws, versus double nuts that are trying to pull threads against each other.
But I will agree that it's not an absolute must to have the Snap On tool. Double nuts work great for most situations. Agreed 100% with mepstein that heat's your friend. I say always use heat where you can. So if you're someone who's going to remove a lot of studs, and they're stubborn studs like the 911 head studs, the collet tool is a REALLY nice tool to have. I finally decided to get the Snap On tool after spending a bunch of time double nutting cam housing valve cover studs over the years. For a while I also used a dedicated remover tool from Goodson that basically works like using double nuts. https://goodson.com/products/standard-stud-removers They don't make them in metric anymore and I wore out the female thread in the tool by needing to tighten it so much to capture the stud w/out the tool spinning on the threads. A lot of people will likely find that tight studs eventually booger the threads in the nuts and you eventually must use a new nut(s). Earlier this year I loaned out my collet tool and had to use nuts on the head studs. I had a bunch of sacrificial M10x1.5 nuts on hand so it worked out OK. But I ended up spending a lot of time on the job and junking a lot of nuts in the process, to get the head studs removed. I'd heat it up with the MAPP torch for at least 2 minutes and apply medium force to the wrench while waiting. They all pretty much came out like mepstein said- 2 to 3 minutes.
Kevin L '86 Carrera "Larry" |
Registered Minimalist
![]() Only way to fly. No heat. Every stud came out perfect.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Before I got the Snap-on tool, I used the double-nut method....both work, but the Snap-On tool is much faster/easier to use. If you are just rebuilding one engine, it may not be worth the cost, but if you plan to do this more than once....or you just like to have the right tools for the job, get the Snap-On.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
One thing to point out about using double nuts is that you are stretching the stud/threads when you tighten them. If you have a stubborn stud that does not respond to heat with the double nuts or the nuts start to slip the natural thing to do is tighten the nuts. The Snap-On collet style clamps onto the threads and will not stretch the stud or mar the threads either. On our engines there are a number of studs that are highly stressed when at operating temperature so any extra added stress risers can cause premature failures. If you aren't going to reuse the studs then who cares, right?
72 2.7 Driven! |
thanks all... Can you use the snap-on collet tool to also install the studs as well?
also... what size are the nuts that are used on the studs? I need to pick some up at the local hardware store to give the double-nut method a try.
Trakrat, You could use the Snap On stud remover collet to install the studs into the case. But why would you use a stud remover to install the studs? Install them by hand or use the double nut method. My Snap On stud remover is so handy and effective that I could remove almost all of them without applying heat and using my impact wrench except for rare stubborn studs. The stubborn stud/s would require some extra heating to pop them loose. ![]() Tony |
I bought this set many, many years ago just because I thought it might be useful someday and it will be in the next couple weeks!
Rutager West 1977 911S Targa Chocolate Brown |
Anyone have a link or links for places to buy these tools, particularly the SnapOn? Anybody want to part with a used kit?
Schleprock
Snap on store has good pricing and quick, fair priced shipping
The tapered collet style stud remover is part number series CG500 https://store.snapon.com/SearchResults.aspx?q=Cg500&IsPartsSearch=0&departmentName=Tool%20Catalog
Search stud remover on Pelican and they sell the Snap on tool and collets.
