That sounds right. I remember the valve to the cabin, but forgot the valve that opens beneath the engine.
Thanks. Dave |
Take a look at the tech article on flapper boxes, it show where they are. https://www.pelicanparts.com/techarticles/tom_sharpes/heater_box1.htm One thing to be aware of, without the blower, the airflow through the heater is dependent on the speed of the engine fan, and therefore engine RPM. If you are sitting at a red light at idle, there isn't much heat. |
That’s why we have a gas pedal and lower gears while driving! I never had any complaints with the early style heat exchangers in my 911s or 914-6s. Perhaps defrosting is a bit slower, but once you understand how the system functions, it’s completely logical.
The flapper valve closes off air going into the car, and at the same time opens below the car so that the hot air from the exhaust manifold is vented there.
Edit. Oops, already answered several times above! |
Sitting still for any length of time, you really need to increase the engine RPM to get any significant airflow through the heater. Never really bothered me, but it doesn't change the fact it happens. |
I have a targa not a sunroof car, but are you sure you even need to open the sunroof to get air pressure differential? The vents above the rear window (or on the roll bar in a targa) do that by design.
Tidying up........
http://forums.pelicanparts.com/uploa...1518304819.jpg |
