Engine decluttering
Here is my engine as it is right now:
http://forums.pelicanparts.com/porsche-911-technical-forum/882264-scoundrel-not-outlaw.html http://forums.pelicanparts.com/uploa...1518087611.JPG Its out and I am rebuilding it and the car is in the paint shop having the engine bay resprayed in the outside colour. As you can see, its quite cluttered in there, so am looking for real-world advice on how to de-clutter the engine without harming performance. I have seen people cutting down their airboxes, drilling holes in or replacing them with cone filters. How much of a bad/good idea is this? Secondly, there is too much pipework criss-crossing the engine: How do I get rid of that, or re-route it in a way that I don't have miles of piping everywhere? Finally, how do I tidy the wiring up so that it looks more ordered? I have my own ideas, but having worked in isolation on this car for years now, not all of my ideas are good. |
Search for heater backdate, that gets rid of the hoses to and from the blower and the blower- you hook them right to the side of the fan with a couple of different pieces of tin. Very easy and not too expensive.
If you want the ultimate in clean good looking engine bay, ITB/EFI is the way to go; very slimming for you too as your wallet will get extremely flat afterwards! |
Here’s a good one on the heat backdate
http://forums.pelicanparts.com/porsche-911-technical-forum/937025-backdated-heat-tech-article.html |
No AC and heat backdate on my SC with CIS. I can get to everything (except items behind airbox quite easily.
Do you know where I can get the tinware and will ship to the UK? |
Here my before and after. I got rid of the clutter.http://forums.pelicanparts.com/uploa...1518108604.jpg
http://forums.pelicanparts.com/uploa...1518108631.jpg |
de-clutterage
send your engine to me....i'll provide some serious de-clutterage.
http://forums.pelicanparts.com/uploa...1518109460.JPG regards, al |
In the medium term I'm planning to remove the heat exchangers and do without heating. In order to declutter now I'm thinking of removing the blower and routing the air from behind the turbine to the left heat exchanger and put a plug on the input to the right heat exchanger. Is it a bad idea? There will be no flow at all on the right heat exchanger.
I did a basic backdate with simple tools and $100 in parts. If you buy a custom plate for the driver's side, it will cost more but you'll eliminate the hose twirl.
http://forums.pelicanparts.com/porsche-911-technical-forum/767908-cheap-sc-heater-backdate.html |
I could be wrong. Good luck, Dave |
Heater valves are diverters. It vents the heat under the car.
Type911.co.uk can provide the parts needed for the heater back date. Ditch the blower.
Thanks, Dave |
