Re set car computer?
By unhooking the negative battery cable, does it reset the computer and motronic system in a 1985 911? I know it works on new systems but I know 1984 was the first year for a computer. Thanks.
Old 02-08-2018, 09:32 PM
That Guy
Techno Duck's Avatar
It wont reset anything in the DME.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-08-2018, 09:34 PM
steely's Avatar
I agree with TD, and I have never noticed or experienced any problems after reconnecting my battery cable.
However, I was always intrigued by something I read in the Bentley manual (a great book but with some minor boo-boos here and there), where it states (under the Engine Management section WRT the DME) that the DME "features advanced adaptive control circuitry" that updates performance info into memory. (Bentley 200-2).
I also thought I had read once that this info resets and gets updated sometime after re-connection and driving (how long?), but 1) I can't find it, 2) my own headspace memory maybe faulty, and 3) I don't know why this would be any different from turning the ignition key OFF.
I've disconnected my Batt' may times for safety when working on the car, and have never experienced any noticeable or odd effects.
Sorry for the long no-value-added reply, I just thought I'd mention this curiosity.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-09-2018, 07:16 AM
The 964/993 DMEs do some amount of adaption after battery power is removed and restored according to maintenence manual.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-09-2018, 07:26 AM
No adaptive memory on earlier motronic brains, I think that came in with OBD electronics.
Old 02-09-2018, 08:05 AM
Bill Verburg's Avatar
Gen1 Motronic used on '84-89 911 has nothing to set or reset when the + or - terminals are disconnented
964 has a gen 2 version w/ some adaptive features, mostly related to idle speed
'94/95 993 has motronic 2.10.1 gen 3(OBD1) where other adaptive features and volatile fault memory have been added.
US '96 993 has Motronic 5.2(OBD2) and is even more adaptive w/ even more memory
You can do adaption on 964 or OBD1 993 by starting and letting the engine idle for 10min
Bill Verburg
Old 02-09-2018, 08:19 AM
Diss Member
Quicksilver's Avatar
Bingo!
The 3.2 DMEs simply read sensors and look up those values in the tables stored in "the chip" and do all the ignition and fuel control based on those tables. As mentioned before there is no learned adaptation. It simply looks it up and spits out the result.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-09-2018, 08:25 AM
proporsche's Avatar
Nick..the only thing you can help your self in the future by disconnecting the battery is.When your handbrake warning light stays on .resetting help to reset the warning light so it goes off when you release the hand brake....or if it stays on due to low brake fluid and does not go off after refilling the brake fluid reservoir.
One thing i did to my DME comp is, i made a short cut to the lambda circuit with external switch....so i can shut it off and on.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-09-2018, 08:27 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Actually, both the 964 and the early 993 OBD I DME have volatile fault memory. OBD-II mandated non-volatile memory and freeze-frames for faults.
As others said the 3.2 doesn't retain anything in its volatile memory
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-09-2018, 04:44 PM
steely's Avatar
Many thanks for the responses - sorry for the diversion Nick.
So the Bentley is wrong here? - No wonder I couldn't find anything to confirm this.
Dan
Venetian Blue
Old 02-09-2018, 05:08 PM
I wil say that I have had massive starting problems on my 964 powered Rat Rod. In great part in turned out to be no constant power to the DME. As soon as I got that straight, and let the DME learn the car it starts like a champ. Especially when cold (i.e. winter here in Florida, temps in the 40's) the car WOULD NOT START.
After battery has been pulled, or the DME unplugged you must start the car, and once started let it idle for 10 minutes. After this the DME learns the car enough that it starts great. Pull the DME, and it starts like crap until you do this procedure.
As Bill noted above....my 89 Carrera 3.2 has no such issue when you unplug the DME.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 02-09-2018, 05:22 PM
ischmitz's Avatar
No the Bentley is not wrong here. Even the 3.2 DME has volatile memory and optimizes things during run time. It doesn’t retain it through a re-start though.
Old 02-09-2018, 06:49 PM
steely's Avatar
Thanks Ingo
This is the other paragraph that got me thinking about this in the first place (from 240-4 of the 84-89 Bentley)
This one has to be incorrect.
Dan
Venetian Blue
Old 02-09-2018, 10:58 PM
steely's Avatar
bump
Dan
Venetian Blue
Old 02-10-2018, 04:09 PM
ischmitz's Avatar
Yes that paragraph is complete nonsense related to the 3.2 DME. The 3.2 doesn't learn anything in the first 10 minutes. It only changes mixture as the engine warms up (given the CHT works properly)
The paragraph applies to 964 and 993 (OBD-I) where the DME learns some VE-related coefficients and idle values.
Old 02-10-2018, 05:55 PM
steely's Avatar
Many thanks Ingo
Dan
Venetian Blue
Old 02-10-2018, 06:31 PM
The reason for the post is that I wanted to know if the DME ever got stuck in a too rich or too lean mixture and if taking the battery off its post would reset the computer. But I know now that I just do not have a clean connection from the green wire to the 02 sensor. That will make the car run very rich.
Old 02-10-2018, 06:38 PM
steely's Avatar
Originally Posted by Nick Triesch View Post
..... But I know now that I just do not have a clean connection from the green wire to the 02 sensor. That will make the car run very rich.
Nick, I believe you need to wait the 10 minutes or so after start b/c the O2 is ignored until the engine reaches temp according to the CHT before you evaluate the O2/lamba. Disregard me if this was already clear.
Dan
Venetian Blue
Old 02-11-2018, 08:17 AM
I believe that's what I said, M2.10 just expands on that over the 964 version, both have permanent + and - pin assignments to accommodate this.
Bill Verburg
Old 02-11-2018, 10:21 AM
Per Bosch that is correct
adaptive closed loop A/F control was introduced w/ the 1989 964 Motronic
In this system deviations from setpoint value when encountered cause the control range of the Lambda control system will adapt by moving the map in the control unit. Due to the fact hat this relocated map must be stored, the engine must be run for ~10 min. if the power supply is interrupted, causing the stored data to be lost., Positive adaption is only possible w/ the engine running.
Prior to the '89 964 this was not a feature on Motronic used by Porsche 911
Bill Verburg
Old 02-11-2018, 10:28 AM
