Steve Wong chip. Any thoughts?
I’m thinking of putting in a chip in my 84 targa. Any experience on performance, downsides, or general thoughts in changing the chip?
Old 02-09-2018, 01:25 PM
proporsche's Avatar
Hi ..there are no downsides..just get it,put it in and enjoy the ride;-) you will love it...Steve is a master of his work..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-09-2018, 01:28 PM
You will have a hard time finding someone on this board who does not recommend a SW Chip. Steve is a pleasure to work with, too.
I have limited mechanical experience and was able to do the install on my own. Lots of information on the install is available. Let us know if you have any questions.
1982 W123 300D
2000 986 S
Old 02-09-2018, 01:34 PM
He is THE man for these things. Nobody better, IMHO.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-09-2018, 01:36 PM
my 85 Targa with SW chip and MandK premuffler is an entirely woken up car from stock.
There can be a hint of low rpm - 2k or so - jarring - minor but the only thing that isn't as smooth as stock set up IME
Old 02-09-2018, 01:45 PM
Make sure you communicate clearly to him what your current setup is.. (stock, modified exhaust, etc...).
Also... I've had some different results on the same chip. For example, I purchased a custom chip that was setup for my car with an open exhaust (straight pipes). Strangely enough, the car actually runs better with my stock exhaust on the same chip.
1987 Porsche 911 Carrera Coupe
Old 02-09-2018, 01:58 PM
nb6179505's Avatar
Would it make a car difficult to pass smog in California?
Sent from my Pixel 2 using Tapatalk
Old 02-09-2018, 02:18 PM
proporsche's Avatar
hi NB............nope ,you will pass with no problems
Ivan
Old 02-09-2018, 02:20 PM
Easy install - no special skills required
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 02-09-2018, 02:35 PM
My '85 would do a bit of bucking at low speed in parking lots, etc. before I put the chip in (standard exhaust, etc.). Smoothed it right out; was no longer a bucking bronco. I'd recommend it. No complaints w/ my '88, though, so I haven't bothered.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 02-09-2018, 02:50 PM
Had this in my 1990 c2. loved it. Getting the ecu open was a bit tricky but other than that it was an easy install.
Old 02-10-2018, 08:59 AM
Google or search the forums for Sal Carcella. He has an amazing products for the 3.2 that I am planning to use instead of the SW Chip. Ask around and do your own due diligence, but everyone I speak with says he's the real deal, just not as well known.
Rob Cully- Virginia Beach, VA
88 911 Carrera Coupe "88 Ducktail" - Black
2008 Cayenne GTS - Nordic Gold Metallic
74 Porsche 911 Targa - Slate Blue
72 Datsun 240Z (sold)
Old 02-10-2018, 09:42 AM
proporsche's Avatar
well? of course there are more people who do the chips..for example i used to have Autothority Chip from east coast or California based Australian company Power-Chip..so far the best was for me S.W. chip.
Ivan
Old 02-10-2018, 10:11 AM
My advice would be to give him a call and discuss your objectives and your concerns. He's a straight shooter and very knowledgeable.
Richard
87 Targa
20 LS 500
Old 02-10-2018, 02:03 PM
sugarwood's Avatar
This was my report
Originally Posted by sugarwood View Post
I installed the Wong chip today.
The car idles higher when cold.
Instantly revs to 1100-1200, instead of hesitating for a second or two, and then going higher.
It is very hard to know how much is placebo effect when comparing the Weltmeister to Wong.
The car seems to pull better when in the wrong gear, like at 2000-3000 range. Seems like less hesitation, but who knows.
I will take it for a proper drive and report back.
1986 Bosch Icon Wipers coupe.
Old 02-10-2018, 03:19 PM
KOH KOH is online now
Steve's chip really improved my car's responsiveness; night and day difference. The engine runs smoother, pulls cleanly from low revs all the way to redline. His installation instructions made the chip swap easy. No downsides in my book.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C
Old 02-11-2018, 09:13 AM
BE911SC's Avatar
Thanks to the OP for the reminder. Just ordered my SW chip.
'84 Carrera Cabriolet
Old 02-11-2018, 12:01 PM
Just ordered mine too. Will post my findings when it arrives.
Old 02-12-2018, 04:43 PM
gruppe f
mikehinton's Avatar
I love mine. And, no problems passing smog in CA.
Mike Hinton
'06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine,
'74 914 1.8 Marathon Blue, '64 356C Aubergine
Old 02-12-2018, 05:18 PM
Kind of Blue
MrBonus's Avatar
I bought mine after four years of ownership and wondered why I waited so long after I did. It really wakes up the lower end of the power band more than anything which improves general driveability.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 02-12-2018, 06:11 PM
