Steve Wong chip. Any thoughts?
I’m thinking of putting in a chip in my 84 targa. Any experience on performance, downsides, or general thoughts in changing the chip?
Hi ..there are no downsides..just get it,put it in and enjoy the ride;-) you will love it...Steve is a master of his work..
Ivan
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
You will have a hard time finding someone on this board who does not recommend a SW Chip. Steve is a pleasure to work with, too.
I have limited mechanical experience and was able to do the install on my own. Lots of information on the install is available. Let us know if you have any questions.
1986 911 1982 W123 300D 2000 986 S |
He is THE man for these things. Nobody better, IMHO.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
my 85 Targa with SW chip and MandK premuffler is an entirely woken up car from stock.
There can be a hint of low rpm - 2k or so - jarring - minor but the only thing that isn't as smooth as stock set up IME |
Also... I've had some different results on the same chip. For example, I purchased a custom chip that was setup for my car with an open exhaust (straight pipes). Strangely enough, the car actually runs better with my stock exhaust on the same chip.
1987 Porsche 911 Carrera Coupe |
Would it make a car difficult to pass smog in California?
Sent from my Pixel 2 using Tapatalk |
hi NB............nope ,you will pass with no problems
Ivan
Easy install - no special skills required
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
My '85 would do a bit of bucking at low speed in parking lots, etc. before I put the chip in (standard exhaust, etc.). Smoothed it right out; was no longer a bucking bronco. I'd recommend it. No complaints w/ my '88, though, so I haven't bothered.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow ![]() |
Had this in my 1990 c2. loved it. Getting the ecu open was a bit tricky but other than that it was an easy install.
Google or search the forums for Sal Carcella. He has an amazing products for the 3.2 that I am planning to use instead of the SW Chip. Ask around and do your own due diligence, but everyone I speak with says he's the real deal, just not as well known.
Rob Cully- Virginia Beach, VA 88 911 Carrera Coupe "88 Ducktail" - Black 2008 Cayenne GTS - Nordic Gold Metallic 74 Porsche 911 Targa - Slate Blue 72 Datsun 240Z (sold) |
well? of course there are more people who do the chips..for example i used to have Autothority Chip from east coast or California based Australian company Power-Chip..so far the best was for me S.W. chip.
Ivan
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 02-10-2018 at 02:15 PM.. |
My advice would be to give him a call and discuss your objectives and your concerns. He's a straight shooter and very knowledgeable.
Richard 87 Targa 20 LS 500 |
This was my report
1986 Bosch Icon Wipers coupe. |
Steve's chip really improved my car's responsiveness; night and day difference. The engine runs smoother, pulls cleanly from low revs all the way to redline. His installation instructions made the chip swap easy. No downsides in my book.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C |
Thanks to the OP for the reminder. Just ordered my SW chip.
'84 Carrera Cabriolet |
Just ordered mine too. Will post my findings when it arrives.
gruppe f
I love mine. And, no problems passing smog in CA.
Mike Hinton '06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine, '74 914 1.8 Marathon Blue, '64 356C Aubergine |
Kind of Blue
I bought mine after four years of ownership and wondered why I waited so long after I did. It really wakes up the lower end of the power band more than anything which improves general driveability.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Thread Tools | |
Rate This Thread | |
