Part ID please
What is this? The piece in question has the wires leading into it and a coil or spring.
1986 911 Grand Prix White
Old 04-10-2018, 09:50 AM
Red Line Service
Marc Bixen's Avatar
A/C Blower fan resistor. The housing is the air inlet for the A/C evaporator.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 04-10-2018, 10:00 AM
Thanks!
Car has heat and A/C deleted so it gotta go too
Old 04-10-2018, 10:15 AM
Before I tossed this part I used it to make a template to block the hole with a thin piece of sheet metal.
1982 911 Targa, 3.0L ROW with Webers
Old 04-10-2018, 10:33 AM
What do you use to cut the sheet metal? Did you get the metal from Lowe’s or Homedepot or someplace more specialty?
Old 04-10-2018, 10:47 AM
I just used a piece of flashing from the harware store, tin snips, a file/sand paper and some paint. Reused the hardware that holds the resistor as well.
Old 04-10-2018, 10:58 AM
