adding turbos to a 3.2
I did a few searches on here but come up empty.
Has anyone ever setup a twin turbo on a 3.2? Anyone know of some links on a TT build?
I came across some article a few weeks back (in Panorama or Excellence I think)... about someone who did a twin turbo setup on a 3.2 and wondering if anyone here had done the same??
I'm not looking at doing this yet... but I might in a few years after I get my current resto/build finished.
1987 Porsche 911 Carrera Coupe
Old 04-06-2018, 07:45 AM
Grappler
Rodsrsr's Avatar
I don't see the benefit of that on a 3.2 which is probably why you wont see many threads on it. More piping, more weight, more complications, and more cost for exactly what gain?
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 04-06-2018, 09:52 AM
Vintage Owner
Jack Stands's Avatar
I seem to remember that someone was making a supercharger for the 3.2 (or perhaps the SC) back in the day. Might be an easier install if you’re committed to the modification.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-06-2018, 10:00 AM
Sboxin's Avatar
You might call Chris at TuboKraft in Mesa, AZ
A few years ago I was able to drive one of his Turbo Boxsters - amazing torque
Turbo Kraft Porsche Parts and Custom Builds | Porsche Service Arizona
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 04-06-2018, 10:06 AM
Grappler
Rodsrsr's Avatar
The OP is asking about TWIN turbos.
Grappler
Know Gi / No Gi
Old 04-06-2018, 10:09 AM
Chain fence eating turbo
Twins spool far sooner (turbine wheel much closer to exhaust valve) than large singles and in general, provide more CFM
Old 04-06-2018, 10:22 AM
Formerly known as Syzygy
Canada Kev's Avatar
Plus, the turbos would necessarily be much smaller and thus spool quicker. Unless one was planning sequential turbos which would indeed be silly to add to a 3.2.
Kevin
Old 04-06-2018, 10:38 AM
Originally Posted by Canada Kev View Post
....... sequential turbos which would indeed be silly to add to a 3.2.
Sequential yes, but compound turbos would be awesome!!!!
I have my old HX40 sitting on the shelf, and it's crossed my mind to stuff it full of the Borg S366 boost!!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-06-2018, 10:59 AM
Eng-o-neer
Tremelune's Avatar
Why would two half-sized turbos, each connected to half the motor's exhaust outlets, spool up faster than a single turbo connected to all of them?
Old 04-06-2018, 11:32 AM
Canada Kev's Avatar
Mass and inertia. Think of how the original 930s were with that huge lag compared to more modern smaller engines with small turbos and their very low lag. Mind you, modern turbines have come a long way, but physics is physics. Or even old cars like a 959: small 2.8L engine and small turbos and as I understand not horrible lag, but still pretty high pressures.
Kevin
Old 04-06-2018, 11:43 AM
Eng-o-neer
Tremelune's Avatar
Given the same amount of airflow, a larger turbo will take more to spin up than a small turbo, but in a twin turbo setup, aren't you using half the airflow per turbo (one for each three-cylinder bank)?
What's the size threshold at which two small turbos will be at desired boost faster than a single larger turbo, given the same total exhaust airflow and same pressure at the intake manifold(s)?
Old 04-06-2018, 12:12 PM
Turbonut
Raceboy's Avatar
With two turbos you are not mixing up exhaust pulses. Twin scroll turbines serve the same purpose but many single turbo systems use regular single scroll turbine and that has noticeably worse transient response and boost treshold under otherwise equal conditions.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-06-2018, 12:16 PM
All about exhaust pulse energy. The turbine wheel is getting hit with hotter air closer to the exhaust valve.
The longer the distance, the slower the spool as the volume of air is compressing and getting colder the further away from the turbo.
Old 04-06-2018, 12:31 PM
Cars and Cappuccino
tdw28210's Avatar
I'd talk to Bisimoto Engineering.
Porsche 930 IROC Twin Turbo – Bisimoto Engineering
Not sure if it is a 3.2 but is definitely twin-spooled.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-06-2018, 01:12 PM
That thing has a 996 watercooled engine in it
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 04-06-2018, 01:16 PM
Ruf did exactly this with their 1987 Yellow Bird, with great success. There is plenty of pictures and documentation on how Ruf built and set up their twin turbo based on the 911 Carrera 3.2L.
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 04-06-2018, 01:37 PM
I had thought RUF did a little more than just slapping some turbos on it.... I had thought everything was custom designed and built specifically for their engine (turbos and all) and they even bored the engine out.
I was just curious if there was a tested setup with a couple turbos and engine management that someone had tested.
I've 'heard' that these 3.2 engines are capable of making 700+hp... but I'm not sure what all that involves.
Old 04-06-2018, 02:46 PM
Grappler
Rodsrsr's Avatar
I guess my point was that there is a cost per benefit, even a cost per HP. Whats the car going to used for, professional competition or street fun? I'm running a Precision single turbo on my 3.2 with stock compression and I can tell you there is very minimal lag and it spooks up quite nicely. Would a twin turbo setup deliver more performance? Maybe it would, but for a street car its fixing a problem that doesn't exist. Additionally it wouldn't make sense to build an over the top twin turbo monster and connect it to a stock 915 gearbox. I know the OP didnt say this was his plan but I think more information is really needed before deciding definitively which direction to take with the build. Dont build a motor around whats best, rather whats best for the specific need. A well tuned single turbo on a stock compression 3.2 is more than enough for most street applications, unless one plans on joining street outlaws.
Grappler
Know Gi / No Gi
Old 04-06-2018, 03:07 PM
FstTarga's Avatar
Single or twins all I can say is it’s a damn good time. I’d go with a smaller turbine than what I did if going single however, I have some good lag
1987 CherryRot Targa: stock 3.2, Presicion Turbo 5976, custom intercooler(made at home), Tial 44mm wastegate, Walbro 255 in-line, Aeromotive fpr, Seimens Deka60 injectors, RarelyL8 headers, DiyAutotune boost control solenoid, Coil on plug, MS3Pro, running .5 bar currently
Old 04-06-2018, 03:57 PM
Canada Kev's Avatar
It was Ruf. Of course they engineered the hell out of it. Built a special turbo tranny with an extra gear, and who knows all the other stuff. It was a 3.4 litre engine, but those pistons and barrels were likely available from Mahle. I read somewhere that the suspension wasn't even all that special. It was factory torsions and upgraded sways, or upgraded torsions and factory sways, one of those options. But I digress...
The engine itself? I have no idea, but it was likely a wee bit more than just slapping on a couple turbos and calling it good.
Kevin
Old 04-06-2018, 03:58 PM
