Twin turbos is not the way to go on these older flat 6 motors. What you want is a single TWIN SCROLL turbo.
Chain fence eating turbo
Would he have made the same with a 88-96mm turbo? Maybe, but they’re hard to spool when that big with our little motors. |
Your example is the fastest 964 probably on the planet. Wow. Let's talk about UGR Lamborghinis. A single twin scroll turbo will get you most of the way to TT power levels with a tiny fraction of the expense. |
IF your going to do it there is a set of 993 turbos, headers, and engine mount for sale right now pretty cheap. All ready fit to a 3.2 ... just need to get piece together the oil returns and intake and tune.
Eng-o-neer
Doesn't a 3.2 need more than just a turbo slapped on? Stronger...internals? Lower compression or something? How much can you boost this thing and not have to rebuild it every 50k miles?
I'm stock in the land of smog checks, but I dare to dream... So like, here's some threads...$3-5k for 300 whp seems pretty sweet, if motor longevity isn't compromised. https://rennlist.com/forums/911-forum/667080-carrera-3-2-n-a-to-turbo-conversion-how-to.html I want to turbo my 3.2L carrera Very custom. Very involved. Very interesting. Last edited by Tremelune; 04-07-2018 at 05:28 PM.. |
It's run it like that since 2008, I did a rebuild months ago after a couple of leaks and some smoke, the engine had never been apart. All that was discovered was 2 valve guides that needed replacing. Everything else inside including piston and barrels looked new. Remember the bottom end is pretty much the same as a 930, crank and conrods, the 3.2 benefits though with much better flowing heads and intake manifold. A 3.2 will make a lot more power at the same boost levels than a 930. I use a small ball bearing GT30R turbo. The car is so much better to drive than a standard 3.2 IMO in every way, whereever a 3.2 has power it has it plus more, no compromises, it's night and day. I went down the path of changing mufflers, chips, headers, they really do very little, sounds is about all you achieve there. I have a stock and turbo 3.2 in my garage to remind me of life without power. ![]() ![]() ![]()
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Eng-o-neer
Well hell. Does it weigh more than a stock 3.6...?
Man, this site is the opposite of Buddhism...Now I need to find a '75 car I can blow up... Last edited by Tremelune; 04-07-2018 at 08:13 PM.. |
Grappler
Same here.... very similar setup as Spence. Precision turbo .5 bar with stock compression, Headers, outlaw muffler, web 20/21 grind cams and a MAF. Not sure about the weight of the 3.6 transplant cars. I only know they dont stand a chance.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
I can get exact numbers on any weight added with my set up in a day or 2. All I can say, is all I added was a turbo, intercooler, blowoff valve, and wastegate.
Otherwise it’s stock. So I’d guess it’s maybe 60+-10 pounds I dk what a 3.6 weighs
1987 CherryRot Targa: stock 3.2, Presicion Turbo 5976, custom intercooler(made at home), Tial 44mm wastegate, Walbro 255 in-line, Aeromotive fpr, Seimens Deka60 injectors, RarelyL8 headers, DiyAutotune boost control solenoid, Coil on plug, MS3Pro, running .5 bar currently |
Wow cool you’ve gone further than me! Yep a stock 3.6 conversion wouldn’t touch the power. Racing a friends 993 vario, it really wasn’t a race, by the top of 2nd gear the turbo 3.2 is ahead by about 5 car lengths. What I like the most is the torque and power lower in the rev range, you don’t have to rev them to make power when you have boost, the 3.2 is so ordinary NA below 4500rpm.
Turbonut
People tend to think that highly built 300 hp n/a is fast until they are reminded by some boosted but otherwise stock 911
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
![]() Of course then there is this - the fully built 3.3 turbo. I built this motor for my turbo targa. Twin plug, giant twin scroll turbo, full width intercooler, CP rods and pistons, EFI, AEM Infinity, all the bells and whistles. Approx 600HP in a 2600HP car. Should be nuts. |
Under the radar
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Eng-o-neer
Agreed. Plus, 300hp and air conditioning...
Anyone can build a hot rod. It's tough to increase performance while keeping the balance of a daily driver. |
Ive been side tracked by my water cooled turbos, though I'm doing a 71' build now so I haven't got the turbo project running. BUT a few thoughts.
Yes a Modern ceramic bearing twin scroll is likely the best bang for the buck. Sure you can use 993 manifolds, but remember to flip the flanges. I am using NA 993 manifolds to put turbos near back corner. I'm using GT28's with 996 IC's and the 3.2 intake with 3.2 heads on 3.3 P&C's. With a hot rod, the final specs and outcomes are rated in more than pure performance numbers OR you'd never see a T bucket or a Harley built up. Its for the challenge, the cool factor and some times just for the "so it can't be done". I'm still on fence of using a G50 or something different. IF you want twins, then just plan to spend a little more. I see the limiting factor to be a factor of combustion chamber, heat dispersion and the problem with too much boost at low rpm's. These are all corrected for with water, but then you get the water pump and all that goes with it. Cheers
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
