Munky King's Avatar
Sorry - Another 'What's this wire?' Question.
I've just taken my steering wheel off to get to the ignition so I can pull it out.
The bottom cover of the steering wheel cover had to come off as well - three screws, and suddenly I'm presented with a wire, I'm not sure where it came from.
Car is a 1975 ('74 build) 911s.
This is the wire:
It looks like it may have been behind the side screw that held the bottom steering column cover on. I can't check though as my cars electrics are a mess!
I've tried looking at my wiring diagram, but there are a few brown wires on there to choose from
Any and all (well most) input appreciated!
Old 03-07-2018, 03:10 PM
ROW '78 911 Targa
timmy2's Avatar
Likely ground for the turn signal/hi/low beam switch. Can you follow it back to it’s source?
Brown is ground.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-07-2018, 03:31 PM
Munky King's Avatar
Thanks for the 'Brown is a ground' comment. At least that might help me find what isn't working until I ground it out in the future!
So far I've only touched three screws:
I wonder if it came from one of these?
This is a closer look at that side:
Following it back is a good option, but if anyone knows where it goes, I would be really grateful. I don't really want to dismantle the dash much more. I'm only as stuck as I am, as I didn't get the right key, when I bought the car from an estate sale (as a project).
Damn theft safety lock mechanisms!
Old 03-07-2018, 04:20 PM
xbmwguy's Avatar
That ground wire goes in between the lower clamshell and the steering column when you reassemble
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 03-07-2018, 05:14 PM
Munky King's Avatar
Thanks.
Does it get crushed on by the screws, or a trapped fit?
Thank again!!!
Old 03-07-2018, 05:20 PM
911 carrera 3.2 (1985)
kees's Avatar
Picture from a 911 1985...probably the same
Old 03-08-2018, 02:14 AM
Munky King's Avatar
Perfect!
Thanks so much everyone!
I know what to do now when I reassemble it all.
Very much appreciated.
Old 03-08-2018, 02:37 AM
xbmwguy's Avatar
It goes where kees shows in the picture, however, it is “sandwiched “ between the plastic clamshell and column
Old 03-08-2018, 02:39 AM
sugarwood's Avatar
Here is another photo that is more clear.
Bottom right screw
1986 Bosch Icon Wipers coupe.
Old 03-08-2018, 03:52 AM
Munky King's Avatar
Thanks everyone for the detail and taking the time to post up pictures.
It's a great help.
So this weekend, I'm going to try to finally get that lock out to get a working key!
Old 03-08-2018, 06:04 PM
