I see pictures of them ...., the P10 , the P10B and the P10C....how do they work? Will any of the 3 work on a 912 cyl head? Any leads or info would be greatly appreciated ( I have searched)
![]() Thanks,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
![]() The tool is for setting the exact valve spring "stack" or height rather than load or tension. For a 912 you need the P-10B You insert the tool in place of the valve spring when doing you final steps in a valve job..the book as an exact spring height needed..you check the graduations on the side of the tool and add or remove shims from the base of the lower valve spring location to get the "stack" right where it needs to be. Do that and repeat on each valve location. Special order here: Porsche Special Tools & Information Last edited by db_cooper; 03-14-2018 at 11:09 AM.. |
Thank you very much!
You can do the same thing with a 6" scale.
I was wondering about that, seems just some careful measurement would do the same thing
