FstTarga's Avatar
Turbo 3.2, ms3 knock detection set up
I’m just wondering if any of the more adept and knowledgeable efi guys on these forums have suggestions for how to properly configure the knock sensor settings in ms3pro. I’m currently running 7psi through an intercooler and have a very conservative timing table, I’m hoping that with the knock sensor properly configured I’d be able to go more aggressive without too much risk to engine health. Thanks
Old 03-19-2018, 10:20 AM
Chain fence eating turbo
I have nothing, but I want to see your engine, turbo, and IC setup.
Are you stock compression ratio with the 7PSI?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-19-2018, 10:47 AM
FstTarga's Avatar
Yea I’m stock compression. Made 284 at the wheels with a super restrictive air filter, I’ve removed it and made an intake with a much larger filter and my whole in boost VE table is now a full point leaner than it was lol
My set up is pretty basic I have a Precision turbo 5876 with a .82 AR, sitting on some crappy OBX headers that I’m gonna replace with rarelyl8 stuff soon and a cxracing intercooler that has had the end tanks severely modified, 600cc injectors, ms3pro running coil on plug. It’s working pretty well now and it’s pretty quick, I just want to make sure it’s quick and safe.
It has a set of 18s that I was test fitting on it in these pics but this is what it looks like now
Old 03-19-2018, 11:17 AM
dos531's Avatar
What settings are you looking for? The way I did it was to add a tank of 100 octane to make sure there was no knock, then monitor the knock sensor levels. Since I know it's not knocking I consider those normal noise levels and set the threshold a little above those levels. There is some trial and error involved so I err on the side of caution. Are you running sequential or batch fire? When using the knock control on batch fire it was extremely noticeable when it pulled timing. Now that i'm on sequential and have individual cylinder knock control, i cant even feel it because it only pulls timing on one cylinder at a time.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 03-19-2018, 12:24 PM
Garen's Avatar
A Starion/Conquest!!! Awesome!!
I've been through 5 of them back in the day. Would modify the heck out of them, before they had any sort of serious aftermarket support. To me, it was like a more affordable 944 Turbo. Can't tell if yours is a Mitsu, hard to see the detail on the taillight from the photo.
Cool 911 by the way, and like Cory, I got nothing for the knock question. But at least the thread gets bumped up and maybe someone will chime in. Also, try posting in the turbo forum, lots of folks have had to deal with exactly what you are wanting to do.
Garen
GNdesignLLC.com - Automotive Art & Sculpture
Old 03-19-2018, 12:32 PM
FstTarga's Avatar
I’m currently running batch injection and ignition, but it’s wired for sequential, I just don’t have a cam position sensor yet. I’ll just go ahead and datalog a bit with some 100 octane in the tank and set my threshold with that in the tank, that should work well enough for me.
Old 03-19-2018, 12:58 PM
FstTarga's Avatar
It’s a conquest btw, it’s my friends project he’s gone through 2 of them, the first one he put multiport fuel injection on it and a 19c turbo and it was quick.
Old 03-19-2018, 12:59 PM
dos531's Avatar
Do it! Sequential made a big difference for me. Adding the cam sensor was actually really easy, let me know if you need any help with that. Also make sure you have the bandpass frequency and everything for the knock sensor set up correctly for your engine size.
Ducati 748R
Old 03-19-2018, 01:04 PM
FstTarga,
Where is your knock sensor located? You will probably need to adjust the gain for each cylinder due to different distances to the sensor and the fact that some cylinders are noisier than others. Just take some easy driving datalogs of Knock #1 - #6 to see what the levels look like compared to each cylinder and adjust the gains so they are about equal. Then as dos531 suggested go out and do some hard pull datalogs with high octane to how high the levels go to set your threshold. You should be OK as long as you don't get carried away with advance in the high boost areas.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 03-20-2018, 01:23 PM
FstTarga's Avatar
That’s what I figured. My knock sensor is bolted to where the stock crank and reference sensor bracket mounted. I’m planning on moving it to the mounting stud for the throttle bracket next time I have the engine out. I wasn’t I initially planning on running knock sensors due to hearing that air cooled engines are too noisy. I’ll spend some time adjusting the gain and see what happens. My timing is super conservative right now so no worries if knock as of yet, I want to run 10psi once I have it totally dialed in at 7, and that’s when I really want the knock sensor.
Old 03-20-2018, 02:10 PM
You can use this site to find the approximation of your center frequency based on cylinder bore size:
https://www.phormula.com/KnockCalculator.aspx
Based on your 95mm bore, your center frequency starting point should be right around 6.0 kHz
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 03-20-2018, 02:13 PM
Very cool car. The 3.2 and 3.6 engines respond so well to boost.
Yeah, sounds like you're about 20-30hp down with the filter. I went EXACTLY through the same thing.
Had no idea how restrictive my filter until I put a larger turbo on, and it wouldn't make boost. Opened it up and it started making nice boost.
Old 03-20-2018, 02:26 PM
Originally Posted by dos531 View Post
Do it! Sequential made a big difference for me. Adding the cam sensor was actually really easy....
I so want MS3X and have my dizzy sitting on the shelf when the time comes.
Old 03-20-2018, 02:27 PM
FstTarga's Avatar
I highly recommend going coil on plug, it was surprisingly easy to do. Just need to finish my sequential setup
Old 03-20-2018, 08:47 PM
Targa,
What brand and part number for the CoP's you are using if you don't mind please? Are they smart or dumb?
Peter
Old 03-21-2018, 02:34 AM
FstTarga's Avatar
They are logic level coils off of a VW 1.8t they fit without having to do any extra work at all, no brackets no hold downs, nothing. Rasant products actually will sell you the coils and wiring for said coils if you just give him a call, Andrew was very helpful. Megasquirt can run them fine just set cranking dwell to around 4.0ms and set it to 3.0ms of dwell when running, I’m using 1.5ms of spark duration and am getting a good strong spark.
Old 03-21-2018, 08:33 AM
MS3Pro spark outputs can handle more current than a MS3X board. So the VW coils will likely be OK with the Pro, but could be an issue with MS3X as reported on the Megasquirt forums in the past. Maybe newer VW coils have a higher logic circuit impedance now. Toyota/Denso COP's and LS2 coils are OK with MS3X, even in dual plug configuration. But other coils can overload the MS3X spark outputs, so a driver/interface board will be necessary. If I remember correctly, my LS2 logic circuit measured around 10K ohms. "xbmwguy" on the Turbo forum has run twin plug Toyota COP's with MS3X for several years with no issues.
-Dennis
Old 03-21-2018, 11:29 AM
