I need some feed back.
What is wrong with this Idea.. I need some feed back..
![]() T I A Jorge (Targa Dude) ![]() PS. Anyone wanna try one out? Free of charge.
Formerly bb80sc
Hmmm, seems that it *may* be difficult to push on the pedal, or get much feel at that location. Also, to be effective you'd probably want the brake and accelerator pedals at the same height to start. Then again, I am not a heel and toe expert
I usually just double-clutch it. Flame suit on!
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
One problem I could forsee is that your pedal is very close to the fulcrum. Therefore your blips might be rather erratic since you will need more force to accomplish the desired effect. I know that other manufacturers out there have them low too but I prefer having the top of my accel. pedal closer to the top of my foot so I can roll the outside of my foot onto the gas to accomplish the blip. It's a nice looking piece though!! What kind of CNC did you make that on?
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS Last edited by jpachard; 02-21-2003 at 01:32 PM.. |
Hey,
Um, scrubbing off speed at the same time you want to accelerate? Too damn close I say. regards,
Jon '85 Targa (recently acquired by Coollx) '02 Carrera 4S (holy moly...I'm in heaven....in the snow too) '06 BMW 325i (gone and forgotten) '03 Honda Odyssey (more dings every day....thanks wifey) |
My car seems ideally suited to heel & toe without anything like that. While braking with the ball of my foot, I can twist over & blip with my heel pretty comfortably. I don't even have big feet. A little flat maybe..
~Hugh '84 Carrera |
Hi James, I ran these on My small manual mill in my garage..
just tooling around.. Jorge (Targa Dude) |
Cymru am Byth
Nothing wrong with your ingenuity, you have saved yourself $150 and I bet it works just fine..
I covered my pedals with 1/8th inch aluminum, and drilled them for the racer look, cost me $6 dollars and about 4 hours labor. I shimmed the throttle pedal with some plywood so it was at a better height for heel/toe. Maybe you might fabricate sometning to cover the whole pedal.
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams Last edited by carmad; 05-14-2014 at 08:08 AM.. |
Looks good for people who actually "heel-and-toe" with their heel. I prefer doing it with the ball of my foot on the brake and rolling my foot slightly using the right edge of my sole to blip the gas. The 911 is the only car I've ever owned where the pedal separation (both left and right and in and out) was already perfect.
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Hi Jon, it's really not that big... it only sticks out 2-1/2 inches from the left side of pedal. I will mount it on my car this weekend and take some more pics. There is actually plenty of room between the Brake pad and Heel pad.
It'll be legen-waitforit
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
I'd think a bit about the torsion being put into the hinge by the twist you'll have by being off-center. If it's flexing plastic at the bottom of the pedal I'd expect that to fail.
Otherwise it seems that it will work after you get used to the feel, blips are a matter of timing as long as you can learn to work the pedal. If you can't get happy with that design, make the extension taller. |
Hi Charlie, in this set up there is plenty of area displacement..there is no flex at all.. Have you ever had the gas pedal off? The honey combe characteristics of the plastic mold are very stiff.
